post #191 of 198 (permalink) Old 09-08-2014, 09:08 AM
QUESTION; will 1200 shocks fit on 1500? distance between eyes on 15 air shock are the same as 12's. As you can see learned to put progressive springs into stocker's, & keep track of parts. Thanks to Gambler!!! They work great, dampers would be better with springs of course but cash is always in short supply!! But if i were to upgrade spare pair with springs,dampers,seals,&boots, you have a inexpensive set of progressive's on hand for any 12 or 15 you have, or get in to fix.
triwing is offline
post #192 of 198 (permalink) Old 10-25-2014, 01:52 PM
1200 85 gw Shock fluid
Hey how much tranny fluid do u use for each shock..
thx gumby
gumby is offline
post #193 of 198 (permalink) Old 08-01-2015, 06:53 PM
Year: 1984
Model: GL 1200 Aspencade
shock rebuild, gl 1200
Interesting post Gambler. There seems to be some information missing though. #1. Does the top shock mount unscrew before you just "popped it off"? Also, #2, you seem to have left out removal of and installation of the new springs, seals, etc. Please update your post.
ScrappyDo is offline
post #194 of 198 (permalink) Old 04-09-2017, 05:03 PM
Model: GL1200AF
Please tell me what the flanges on your spring compressor are from. Where can I get them. Thanks buddy, great post 😊😊
Dawntreader27 is offline
post #195 of 198 (permalink) Old 04-09-2017, 07:02 PM
Originally Posted by Gambler View Post
this is the tool I made to compress the springs. it consists of 2 1 1/2 inch floor flanges, the top flange is bored out to 2.125(approx. 2 1/8 inch diameter). the bottom flange has a standard plug screwed in to hold the shock end. the threaded rods are 3/8 by 16 all thread, 2 foot long. I double bolted the top flange with grade 8 nuts and hardened washers. The drive nuts are grade 8 with 2 greased hardened washers to reduce galling and friction. use at your own risk, but it worked for me.
Originally Posted by Dawntreader27 View Post
Please tell me what the flanges on your spring compressor are from. Where can I get them. Thanks buddy, great post ����
Post #3, from a hardware store.
[SIGPIC]
post #196 of 198 (permalink) Old 04-10-2017, 01:43 PM
Model: GL1200AF
Thanks Dave I will get to work
post #197 of 198 (permalink) Old 05-12-2017, 11:52 PM
Model: GL1200AF
Which way up does the ring go inside the shock that is flush on one side and has a recess on the other? Thanks
post #198 of 198 (permalink) Old 05-13-2017, 05:48 AM
The flat side goes toward the seal.
[SIGPIC]
Got the tools, doing the shock rebuild on GL1200 chris in va Goldwing Technical Forum 8 06-24-2012 11:32 AM
Shock Rebuild on GL1200 Bike...and Dennis Goldwing Technical Forum 19 12-22-2009 09:41 PM
GL 1500 shock rebuild GLJohn Goldwing Technical Forum 2 07-19-2007 04:01 AM
85 LTD Shock Rebuild Snorebaby Goldwing Technical Forum 3 04-24-2007 06:04 AM
GL1200 ltd shock rebuild travelinmays Goldwing Technical Forum 9 06-06-2006 06:16 AM
