post #61 of 68 (permalink) Old 06-02-2014, 12:52 PM
Model: 1976 LTD (X2) (two apart in VIN)..... 1976 GL1000 Sulfur,... 2008 Pearl White
I have used these on GL1200 and GL1500 shocks:
Monroe Shock-Mate Boot Kit SA1997
You have to trim them to length, and when fitting on the 1500 you need to trim the bottom to clear the mount bolt.
Please note that I found this interchange info elsewhere on this site, and have used a few of them, but I thought it would be good to have on the main list.
Bill
77Pinto is offline
post #62 of 68 (permalink) Old 05-10-2015, 11:00 PM
Model: 82 Aspencase & 82 Interstate
CCsailor and all others who have contributed to this link: THANK YOU! I'm a new member of the site, but an old Wing owner. Poking on the site for general info (restoring my second 82 Aspencade), I found this thread and figure you have saved me dozens of hours and hundreds of dollars (and maybe a few cuss words to boot.) My thanks to all....
-- singlewinger60
singlewinger60 is offline
post #63 of 68 (permalink) Old 06-06-2015, 03:06 PM
jhngardner367's Avatar
Model: 1984 GL1200 I (California)
Just for reference,upper and lower rad hoses are the same on Gl1000/1100/1200.
So,you can use the NAPA #7733 to make both upper,and lower hoses.
"I can't fix it ,if it ain't broke...ya want me to break it, first???"
Expect the unexpected. But don't expect the unexpected to be the unexpected you expected !
"I'm busier than a one-legged cat,in a sandbox !"
" Give me a Goldwing,or give me VIAGRA...CUZ either way, I'm Gonna RIDE!!!"
jhngardner367 is offline
post #64 of 68 (permalink) Old 08-23-2015, 10:10 AM
Year: 1949,1971,1980,1981
Make: harley and 3 hondas
Model: gl1100
Send a message via Yahoo to dusterdude
since im in the market for 1100 belts,has anyone confirmed a correct part number other than the t274 gates belt?thanks
mark
dusterdude is offline
post #65 of 68 (permalink) Old 08-23-2015, 10:10 AM
Model: gl1100
and also the belt tensioner and idlers as well
mark
post #66 of 68 (permalink) Old 08-23-2015, 12:20 PM
Gates is the supplier for Honda timing belts.
Get them at any auto parts store or eBay or Amazon.
Join us for NASR10 "
SR10 "
Summer Rally #10 at
post #67 of 68 (permalink) Old 08-27-2015, 10:13 AM
Model: gl1100
thanks az
mark
post #68 of 68 (permalink) Old 10-01-2015, 10:59 PM
Silicon Sam's Avatar
Model: 1997 GL1500 SE
Originally Posted by 77Pinto View Post
This is a great thread and have been through it many times, but I missed the detail (if here) about what brake pads are thicker between the FA69, FA69/2, and FA69/3. Can anyone provide that info?
Thanks,
Bill
Sorry it took so long, but you can download the EBC catalog online. Contains all the specs in the back. The FA69 is 10mm thick, the FA69/2 is 9mm thick, the FA69/3 is 11.3mm thick.
Other dimension is 90 x 49mm.
1983 GL1100 Interstate Black
Silicon Sam is online now
GL1500 aftermarket swingarm bearing numbers? newday777 Goldwing Technical Forum 14 08-12-2011 02:36 PM
GL1500 aftermarket radiator hose part numbers needed IRAQI RAM Goldwing Technical Forum 6 03-10-2009 08:50 PM
Aftermarket part numbers scvmike Goldwing Technical Forum 2 12-10-2007 09:39 PM
Aftermarket fuel and air filter part numbers, please. newbiker For Sale/Wanted Forum 5 11-29-2007 05:06 PM
Aftermarket part numbers web page DarinS Goldwing Technical Forum 4 04-26-2007 09:04 AM
