4Likes
post #71 of 74 (permalink) Old 01-26-2016, 08:57 PM
Streetfools's Avatar
Year: 1979
Model: GL1000
Ok guys, I just replaced the tensioners on my GL1000. I just wanted a couple second opinions before I cover everything back up. I used grade 8, 3/8" hardware torqued to 30lbs. I did my best to center the bolt in the larger opening on the tensioner plate before I torqued them. I assume that once they are tightened it won't really matter if the idler is perfectly centered because the spring will compensate. The only thing that concerns me is the washer sunk into the opening on the plate.
I ground down the spacer plate that goes behind the tensioner to allow it to move as usual with the added material from the hex head. Everything seems to work as intended.
Any reasons I should alter what I've done here?
Streetfools is offline
post #72 of 74 (permalink) Old 01-27-2016, 03:04 PM
badorderbob's Avatar
Year: 1981
Make: Honda Goldwing
Model: Gl 1100
Great pictures and glad to see the conversion is working.Just had to share that since I did mine back in 2009, I haven't had a problem. 7yrs.and working great. Thanks again Jim
Streetfools likes this.
badorderbob is online now
post #73 of 74 (permalink) Old 07-30-2016, 11:45 PM Thread Starter
Piled Higher and Deeper
sandiegobrass's Avatar
Just a quick note that the PDFs instructions are back at post 42 or 43 or so..
AKA "Jim"
Have a Gold Wing? Please take the
2000 GL1500SE
1983 GL1100I
But formerly San Diego, Terra Haute, Aiken, Oak Ridge, Tonopah NV, Pasadena, and probably going back to Aiken..)
sandiegobrass is offline
post #74 of 74 (permalink) Old 07-31-2016, 03:19 AM
Great article Jim, glad to see it is still being referenced.
Timing belt tensioner, GL1100 Watchdog562003 Goldwing Technical Forum 4 07-16-2012 11:32 PM
Timing belt tensioner Was Wannabewing Goldwing Technical Forum 10 05-03-2009 06:49 AM
Timing Belt Tensioner michaelhaney Goldwing Technical Forum 4 03-14-2009 09:56 PM
Timing Belt Tensioner DJHoosier Goldwing Technical Forum 9 12-28-2007 08:06 PM
