post #1 of 17 (permalink) Old 04-27-2010, 01:24 PM Thread Starter
pdgriggs52's Avatar
My low fuel light does come on for a few seconds when I first start, and then goes out like normal, but does not come on when gas gets low. I have looked on line for a sensor but have not found one. Also when I take off I hear a clunk like a "U" joint or something, any ideas what to do about fixing either or both my problems.
Thanks
Life is a Highway, Just Wing it.
1996 GL1500 SE - Hit a Deer - It\'s Gone.
2006 GL1800 w/ Champion Trike Kit - Love it.
pdgriggs52 is offline
post #2 of 17 (permalink) Old 04-27-2010, 02:47 PM
Senior Guru
Oregonwinger's Avatar
37810-MN5-008
This is the low fuel thermistor part no. The dealer will try to sell you the whole pump assy, if you go in and ask for the low fuel fix.
37810 - MB4 - 008 from a v65 Magna is supposed to work, also. I think they're the same thing.
Try this page for a guide, but it's more aimed at pump replacement.
http://www.berrysweb.com/Documents/GL1500_FuelPump.pdf
or
http://www.berrysweb.com/1500_fuel_pump.htm
The clunk - -what's the year and model, and what's the mileage? All this info is important. Could be splines and wheel hub that have never been taken care of; IE: no 60% moly applied at 20k miles intervals, or a bad hub in the cushion area. That stuff rarely gets serviced, when tire is off.
Real shame, too
BOB
Oregonwinger is offline
post #3 of 17 (permalink) Old 04-27-2010, 07:02 PM
Just another ORF!
Dusty Boots's Avatar
Model: 92 1500 Aspencade
No biggie to change out the low fuel warning sensor
Remove the seat and pull apart the 3 quick disconnects and the three nuts and remove the fuel pump. You'll have to angle it out and then remove a breather hose and a couple of screws that hold on the actual sensor.
The part number in red is for a 92 Aspy, but I imagine they are all the same. Think I paid $35 for it from Cheap Cycle Parts, winter of 08.
http://www.goldwingfacts.com/forums/forum1/61924.html
Dusty
- just another Rider
Dusty Boots is offline
post #4 of 17 (permalink) Old 04-27-2010, 09:11 PM
Year: 1993 Gold Wing & 1979 Yamaha 650cc Vertical twin.
Model: GL1500
You can repair the low fuel warning light for a couple of bucks with a thermister from Mouser Electronics, Basic soldering skills will get the job done. Disconnect the battery, remove the seat, pull the unit from the tank and take the "can" apart that the thermister is in. If you haven't done it before it may take you about 1 hour to do the job. Usually some of the members here will have an extra one.
Eagledriver is offline
post #5 of 17 (permalink) Old 04-28-2010, 03:14 PM
Anti-Guru
satan's Avatar
Model: '06 GL1800
Oregonwinger wrote:
If only I knew which one. I forgot. Was it 1000 ohm?, or 100 ohm? I'm pretty sure it was it was negative coefficient, tho. A cpl bucks, vs Honda's outrageous price.
Should be 1Kohm like the Mouser p/n: 527-2004-1k (clicky)
satan is offline
post #6 of 17 (permalink) Old 04-29-2010, 03:08 PM Thread Starter
pdgriggs52's Avatar
This may be a dumb question, but what the the thermister look like?
post #7 of 17 (permalink) Old 04-29-2010, 03:35 PM
Senior Guru
like a small resistor.
BOB
post #8 of 17 (permalink) Old 05-02-2010, 10:52 PM Thread Starter
pdgriggs52's Avatar
I've ordered 2 of the thermisters, is it inside the little sensor can inside the tank, or am I looking in the wrong place. I took the unit out of the tank just to see what I was looking for and did not see anything that looked like a resistor. If I can find it and get to it I can fix it.
Thanks for all the help so far.
post #9 of 17 (permalink) Old 05-03-2010, 09:11 AM Thread Starter
pdgriggs52's Avatar
I still don't know exactly where the thermister is. Can someone tell me where to look?
post #10 of 17 (permalink) Old 05-03-2010, 09:18 AM
Anti-Guru
satan's Avatar
Model: '06 GL1800
You're spot-on -- it's in the "Little sensor can" in the tank (on the pump assy you pulled to look at).
Lots of these blow when folks fuel up with the key on (especially if the low fuel light's on) due to thermal shock of the part.
satan is offline
Low Fuel Level light sensor GL1500 How to Fix #97600 jmorizi1 Reference and FAQ Forum 7 08-25-2010 02:24 PM
Low Fuel Level light sensor GL1500 How to threads AZgl1800 Goldwing Technical Forum 2 08-08-2010 10:40 AM
Low Fuel Level light sensor GL1500 How to Fix #93975 papasmurf Reference and FAQ Forum 6 06-15-2010 07:27 PM
Low level fuel light, GL1500 not working pdgriggs52 Goldwing Technical Forum 6 05-10-2010 08:13 AM
Changing out GL1500 low fuel level sensor- removing fuel pump Dusty Boots Goldwing Technical Forum 7 12-03-2009 05:54 AM
