post #51 of 56 (permalink) Old 07-12-2015, 09:57 PM
With it almost full, you are most likely going to have fuel all over the floor if you open the fuel pump seal on the tank.
I would place a piece of rubber hose on the pump outlet, let it fall into a gas can, apply 12V directly to the B+ terminal and IF the pump will run at all, it can pump the gas out.
once it starts, it might even siphon the rest of it out.
3 gallons of fuel is about 3 inches below the tank opening IIRC.
failing all of that don't work, roll the bike out into loose dirt.
Open the fuel tank opening and just let the gas run over the top.
stick a hose in the tank and siphon out the rest into the gas can.
Join us for NASR10 "
SR10 "
Summer Rally #10 at
post #52 of 56 (permalink) Old 07-21-2015, 10:07 AM
rrago's Avatar
Model: 98 GL1500Se - "Black Dog"
Air Hose??
I've decided to carry a replacement pump with me. I understand the replacement instructions, but I'm curious about the "air hose" that no one seems to be worried about not replacing.
Where does that fitting inside the tank lead to? It's not a tank vent. So where does it go?
rrago is offline
post #53 of 56 (permalink) Old 12-24-2015, 08:45 PM
mike@mikeblakeney.com's Avatar
Model: GL 1500 SE
Just an after action report.
My 97 SE was hesitating on acceleration and recently began trying to quit at
highway speed.
Using this thread, I replaced my fuel pump with the....
Carter pump P72190 this afternoon.
Purchased on Amazon for $41.
Some new fuel line, a couple of clamps and a 90 degree brass elbow cost me another
$25.
I took time to clean up all the electrical connectors, nuts etc.
The rubber gasket looked perfectly fine so I re-used it.
Everything went smooth until I needed to determine which of the leads (cut from the stock pump)
was positive and which was negative. The Carter pump has a + & - for the leads.
(if that was covered earlier I missed it)
So I hooked it all up outside the tank and turned on the key and tried my best to determine +- voltage
but was unsuccessful using normal testing techniques. Yes I did hit the starter.
Each wire appeared to supply current when one probe was on ground. Reverse the probes and the current reversed
on both.
So I just touched the leads to the pump and it appeared to kick in so I hooked it up what way and
put it all back together.
Of course it was not correct so I had to drain the tank again and reverse the leads and everything worked
perfectly. Test ride was perfect and it's running with much quicker throttle response and the hesitation
is gone. I have not had it on the highway yet.
(I had already replaced the coolant temp probe suggested on another thread which corrected a perpetual rich
issue.)
Now, it's getting a petcock rebuild whether it needs it or not.
Slowly but surely I am getting her road ready.
I've already done the fuel and air filters.
I plan on replacing the timing belts, radiator hoses and alternator before spring.
MikeB
97SE
mike@mikeblakeney.com is offline
post #54 of 56 (permalink) Old 12-24-2015, 09:10 PM
wonderful report Mike,
glad your new acquisition is going to be road worthy come spring.
I don't recall if anyone mentioned the wiring for the Carter pump. I do remember that it has separate leads.... IIRC, one was red, the other white?
or maybe it was Black and White.
Black is positive in the car world, and white is negative
SR10 "
Summer Rally #10 at
post #55 of 56 (permalink) Old 12-26-2015, 03:43 PM
Model: GL 1500 SE
Hey AZ,
There was a black and blue wire to the the stock pump. I know black is "hot" in house wiring so I went with that and it turned out to bewrong. The Pump I got only had screw terminals with a nut so I had to crimp my own connectors onto the wire ends. The old pump was factory wired so it had no markings. I was afraid to put 12 volts to it since I didn't know if I might damage it. In retrospect I should
have tested it in a bucket prior to reinstalling everything. It would have saved me 20 minutes or draining the fuel again and pulling it back out. I have attached some pics or the pump and the coolant temperature probe I replaced just in case it will help someone.
MikeB
post #56 of 56 (permalink) Old 12-26-2015, 05:17 PM
yeah, reverse voltage on a DC motor will not hurt it, and with the pump sitting in a small container of fuel, you would have known within 2 seconds which wire is for +12
I am always trying to guess what a "black wire" is.... sometimes it is ground which is usually the case on DC systems.
other times, it is the HOT wire in A/C systems... which I always thought was a stupid thing to do... why in the hell didn't NEMA fix that back in the dark ages???
In my house, the electric is all black, every single strand if it is not part of a piece of Romex. the electrician was an idiot... he pulled in a circuit, hooked it up, and moved on.... to hell with documentation or colored tape.
I have spent days of tracing out the wiring in my house, and using a Tapewriter to label the switches. and I still have more than half of them to go.
24 circuits, all black, no labels.
SR10 "
Summer Rally #10 at
LTD, SEi. How to fix fuel pump and where to buy one for $20 newbiker Goldwing Technical Forum 27 04-15-2012 08:14 PM
GL1500 fuel pump replacement tlbranth Goldwing Technical Forum 8 11-01-2011 10:40 PM
1982 1100 Accelertor pump leaking what is an easy fix? ryster Goldwing Technical Forum 3 02-01-2011 05:13 AM
1500 dies fuel pump fix after market anythingoutside Goldwing Technical Forum 5 11-23-2008 05:58 AM
GL1500 Fuel Pump Replacement NeedleNick Goldwing Technical Forum 1 08-02-2008 05:22 PM
