post #1 of 8 (permalink) Old 08-30-2005, 05:57 PM Thread Starter
My speedometer stopped working as well as the turn signal cancel. I have no idea what happen. Is this a cable issue of a speed sensor issue? Thanks
jswantz is offline
post #2 of 8 (permalink) Old 08-30-2005, 07:29 PM
tricky's Avatar
Year: 1985
Model: 85 Aspencade
Here is a test for the speed sensor:
http://www.goldwingfacts.com/forums/...t=speed+sensor
tricky is offline
post #3 of 8 (permalink) Old 08-30-2005, 08:02 PM
Welcome to the Best Goldwing Site on the Internet jswantz!
I'd say tricky got you fixed up! Both functions are linked together through the speed sensor. Could also be the cable.
post #4 of 8 (permalink) Old 08-30-2005, 10:01 PM
johnmac's Avatar
Welcome to the forum, jswantz! The drive gear on the front axle may have worn out, due to lack of grease. That was the problem with my bike when I bought it. You can get just the gear, or the whole drive assembly. The gear is about $15, the drive assembly about $75.
1996 GL1500 SE
Past bikes
1985 Aspencade 1200
1978 Honda GL 1000
1974 Honda 350 Four
1974 Yamaha TY 250 Trials
1973 Yamaha 360 RT3
1971 Honda SL 100
1968 Honda Trail 50
3 1/2 HP mini bike
johnmac is offline
post #5 of 8 (permalink) Old 09-01-2005, 09:04 AM
Other side of the pond
englishted's Avatar
First and easiest thing to check is the speedometer cable, if this breaks then none of the items you mentioned work either.
Ted Kelly.
englishted is offline
post #6 of 8 (permalink) Old 09-01-2005, 12:28 PM
johnmac's Avatar
My '85 1200 Aspencade has the digital dash. The spedometer "cable" is electrical wires.
1996 GL1500 SE
Past bikes
1985 Aspencade 1200
1978 Honda GL 1000
1974 Honda 350 Four
1973 Yamaha 360 RT3
1971 Honda SL 100
1968 Honda Trail 50
3 1/2 HP mini bike
johnmac is offline
post #7 of 8 (permalink) Old 08-10-2012, 07:26 PM
Thank you
Tom Franklin is offline
post #8 of 8 (permalink) Old 08-10-2012, 07:42 PM
Tom Franklin wrote:
Thank you
Welcome to the forum.
If this seven year old thread solved a problem that you were having perhaps you could elaborate.
Ken Bergen is online now
Speedometer not working 1985 Aspencade 66cobra Goldwing Technical Forum 3 09-04-2012 02:54 PM
1985 GW Aspencade speedometer worm gear tommygun48 Goldwing Technical Forum 9 03-07-2012 09:40 AM
1984 GL1200 Aspencade Charging Issues Herm Goldwing Technical Forum 8 08-21-2011 07:28 PM
1985 GL1200 LTD Speedometer Hub eulas For Sale/Wanted Forum 0 07-21-2010 11:26 PM
GL1200 Aspencade Speedometer Ratio Goldwing Rod Goldwing Technical Forum 5 01-14-2010 11:19 AM
