post #1 of 6 (permalink) Old 12-07-2005, 05:53 PM Thread Starter
My Wing speedo reads 70mph when it is actually going 65mph. Has anyone used a speedo calibration kit such as the SpeedoHealer? There was an article in Motor-cycle Consumer News about 3 months ago discussing the use of this product. Does anyone know if it really works and what are the requirements for installing the unit?
Thanks
39wldd is offline
post #2 of 6 (permalink) Old 12-07-2005, 06:30 PM
GERIATRIC MEMBER
Redwing's Avatar
Model: Neighbours 1800
Hey 39wldd This is a common problem on most m/cycles. The fix for this is http://www.blackrobotics.com/yb_home.htm Also have a look at http://www.jahlmandesign.com/gl1800.htm
"Redwing"
Redwing is offline
post #3 of 6 (permalink) Old 12-07-2005, 10:06 PM
I met a guy at the Seattle Motorcycle show who'd installed the Yellow Box on his 1800 and was very pleased. Said he could calibrate it right to the mark.
post #4 of 6 (permalink) Old 12-08-2005, 03:20 AM
yellowwing's Avatar
Yellowbox got good reviews on all the 1800 forums, I'm thinking about this myself as its annoying having the speedo and GPS giving different readings.
Eric.
02 Yellow GL1800.
yellowwing is offline
post #5 of 6 (permalink) Old 12-09-2005, 08:17 AM
Older and Wiser
BenMC's Avatar
Model: GL1500 Aspencade
I'd just ignore the speedo and use the GPS for accuracy.
Ben.
BenMC is offline
post #6 of 6 (permalink) Old 07-14-2007, 09:06 AM
macguiyver's Avatar
just got a yellow box for this.. you can order it from the websiet mentioned on the other posting... for the where to install it go to http://www.pbase.com/fredharmon/yellowbox
Macguiyver>>>
macguiyver is offline
1986 GL1200 speedometer error chuckb01 Goldwing Technical Forum 19 06-12-2012 05:35 PM
Speedometer Error on the 1500 and 1800 Daveo General Motorcycle Discussion Forum 36 12-08-2008 04:14 PM
Speedometer error on 1200 snakebite4767 General Motorcycle Discussion Forum 1 06-12-2007 01:11 PM
Speedometer error Russboat Goldwing Technical Forum 13 09-17-2006 04:56 AM
Speedometer Error airbeat Goldwing Technical Forum 8 05-07-2005 09:19 AM
