post #1 of 38 (permalink) Old 12-27-2005, 06:48 PM Thread Starter
PJB
PJB's Avatar
got 05 wing need to change oil I bought mobil one is that alright to use manuel says no additives. can anybody tell me the best oil to use?
2005 1800A Goldwing
PJB is offline
post #2 of 38 (permalink) Old 12-27-2005, 08:37 PM
welcome to the forum... you will discover we are a friendly group, and will occasionally joke around.... there have been lots of threads on oil changes and brands... and of course, none of us are opinionated (for the record I use mobile one)... but if you want opinions... ask about tyre brands, or, g*d forbide "deer alerts" .....
rcmatt007 is offline
post #3 of 38 (permalink) Old 12-27-2005, 08:52 PM Thread Starter
PJB
PJB's Avatar
thanks haven't changed it yet just got the oil wasn't sure about the additives
book says no additives but the bottle doesn't specify whats in the oil thanks
2005 1800A Goldwing
PJB is offline
post #4 of 38 (permalink) Old 12-27-2005, 09:12 PM
Welcome to the Best Goldwing Site on the Internet PJB!
Do a search on oil in the search box at the top of the page and you're going to see more opinions than you'd believe. Twisty tends to go to the technical end of it so check out his postings. The only recommendation I can give about oil is you definitely should use some.
That at least isn't controversial.
post #5 of 38 (permalink) Old 12-28-2005, 01:16 AM
74cb750's Avatar
Send a message via Yahoo to 74cb750
Really? Oil? Oh-oh. WHere do you put it?
Personally, almost bought some Mobile=1 until I saw the price, and besides I ended up not keeping the bike very long. Go for it.
All controversies end at this forum. All questions are resolved. All answers are correct. Just ask anyone here.
Welcoome to a good forum.
peace,
michel
Life is a joke, unfortunately most people don\'t get the punchline.
74cb750 is offline
post #6 of 38 (permalink) Old 12-28-2005, 11:44 AM
JDuggan's Avatar
Mobil 1 is fine PJB. Most of the USA GL1800 owners use it all the time.
Joe Duggan
JDuggan is offline
post #7 of 38 (permalink) Old 12-28-2005, 11:54 AM Thread Starter
PJB
PJB's Avatar
Thanks i guess i'll be useing the good stuff
2005 1800A Goldwing
PJB is offline
post #8 of 38 (permalink) Old 12-28-2005, 02:46 PM
gkiesel's Avatar
Send a message via MSN to gkiesel
Joe, are you refering to mobil 1 motocycle oil or regular off the shelf Mobil1 car oil?I thought the car oil was bad for your clutch? George.
George K
1984 Aspencade
1999 Kawasaki zrx1100
1995 Honda CR250
1977 KZ400 S3
gkiesel is offline
post #9 of 38 (permalink) Old 12-28-2005, 08:42 PM
twisty's Avatar
PJB, while the oil container has limited verbiage about it's contents,, if you go to theoil manufacturers web site there will a data sheets on the oil giving most of the important additives & friction modifiers..
A real easy to use (general) guide is to just turn the oil container around & look at the back of the container.. On the back there will be an APIcircle --or "donut"
That API "donut" is divided into three parts. The top half of the circle lists the API service rating, (or performance level). The center of the circle is the oil's viscosity. And the lower half of the circle indicates whether the oil has demonstrated certain energy conserving properties. IF, there is anything written in the bottom of the circle (like "energy conserving") then that ISN'T the oil to use in a wet clutch motorcycle.. As a rule, (energy conserving) oil has Molly or Teflon type additives & those are NOT to used in wet clutch motorcycles..
Twisty
twisty is offline
post #10 of 38 (permalink) Old 12-29-2005, 05:49 PM Thread Starter
PJB
PJB's Avatar
Thanks Twisty good info pjb
2005 1800A Goldwing
PJB is offline
GL1800 Oil Change rtdmd Goldwing Technical Forum 4 06-09-2012 09:59 PM
GL1800 Oil Change Wine_r Goldwing Technical Forum 6 04-14-2012 10:16 PM
FIRST OIL CHANGE ON NEW GL1800 Lloyd Goldwing Technical Forum 16 05-27-2011 03:36 AM
Oil change GL1800 remy Goldwing Technical Forum 3 05-18-2011 01:20 PM
GL1800 Oil change ccsial Goldwing Technical Forum 2 07-25-2009 05:40 AM
