post #1 of 6 (permalink) Old 04-15-2006, 02:38 PM Thread Starter
handyrandy's Avatar
Any ideas where to start? What is the first thing to check?
Thanks! Randy
81\' GL 1100 Standard with Vetter 5 fairing with lowers, radio pod and Hondaline suitcase bags and trunk.
handyrandy is offline
post #2 of 6 (permalink) Old 04-15-2006, 02:41 PM
BobbyW's Avatar
Model: 2007 GL1800
The first and easiest thingto check is the wiring connection plug. Mine was unplugged.
[b]-2007 GL1800, Audio, Blue
-1981 GL1100 Standard FOR SALE
Hondaline Luggage/Vetter Fairing
-1978 GL1000, Nekid, Black
[color=gray]List your Wings Model and year in your profile !!!
BobbyW is offline
post #3 of 6 (permalink) Old 04-15-2006, 03:20 PM
Kendas's Avatar
Check both plugs... One at the thermo switch (middle of engine, larger switch in back) and then the one at the fan motor. Next check to see if the fan actually works. Disconnect the fan leads at the motor and carefully connect to a hot 12 volt source.
CAUTION!!! Make sure that fingers are clear of blades... Plastic fan will slice skin to the bone in about a millisecond!
Ken
Ken S. - Old and one legged... But then again the 84 Interstate ain\'t what it used to be either.
Previous Bikes:
1983 Interstate
1975 GL1000 WJ III, Bates Bags, ARE Boot (115K)
2 1972 Yamaha Enduros
Kendas is offline
post #4 of 6 (permalink) Old 04-15-2006, 07:01 PM Thread Starter
handyrandy's Avatar
Will do. Maybe after church tomorrow.
Thanks
post #5 of 6 (permalink) Old 04-15-2006, 09:25 PM
Whiskerfish's Avatar
Key on, Motor off. Take a jumper Wire and stick each end in the connector that goes on the thermo switch. If the fan comes on the Thermo switch is bad. If not then check the fan. About 90% the Thermo Switch is bad.New switch from Mother is pricey like $70. Many bypass the switch and use a toggle instead to control the fan.
WF
Whiskerfish
1975 Nekid Noisy and Nasty
1975 Nekid in pieces parts
Whiskerfish is offline
post #6 of 6 (permalink) Old 04-15-2006, 11:35 PM Thread Starter
handyrandy's Avatar
Now there is an idea!!!!! ThanksWiskerfish!
Randy
1100 cooling fan fuse ol school Goldwing Technical Forum 6 09-14-2012 10:04 PM
83 a 1100 cooling fan allen down Goldwing Technical Forum 6 06-18-2010 06:38 AM
cooling fan gmussell Goldwing Technical Forum 13 07-14-2009 11:54 AM
Running hot cooling fan not coming on GLJoe Goldwing Technical Forum 6 01-03-2009 08:58 AM
82 GL 1100 Cooling Fan kpritz Goldwing Technical Forum 5 12-11-2005 04:40 AM
