post #1 of 3 (permalink) Old 04-22-2006, 08:22 PM Thread Starter
ScottInNV's Avatar
Model: 76 GL1000
hey guys. found that my mystery leak was NOT the shift shaft seal (exclusively) it was the crankshaft seal. I rode into town today, and it was once again leaking heavily from the cam covers. pulled the covers (again) and found a nice trail running from under the crankshaft area. there was a LOT of crud there before, but today I had a good trail to follow (more like a superhighway). anyways, to get the crank bolt off I tried my impact gun......no dice, outta air (i use a 20 lb co2 bottle and regulator instead of a compressor). on a lark, I pulled the 17mm cover for the stator, and used a ratchet to hold the shaft steady, CRANK BOLT CAME RIGHT OUT!!!! no muss, no fuss, just came right loose. for those without access to airtools (or just no air), this method works a champ.
1976 GL1000 Nekkid!!
formerly had
1980 CX500
1981 GL500 SilverWing
1985 Honda GL1200 LTD
ScottInNV is offline
post #2 of 3 (permalink) Old 04-23-2006, 08:21 AM
How hard will it be to replace the crank seal?
87 GL1200I Grey
03 GL1800 Red
wingmaster is offline
post #3 of 3 (permalink) Old 04-23-2006, 09:30 AM Thread Starter
ScottInNV's Avatar
Model: 76 GL1000
its not. took about 2 hours to do the job.
formerly had
1980 CX500
Crankshaft Seal Leaking GL1200 SailorDude Goldwing Technical Forum 13 06-10-2011 03:37 PM
gl1200 crankshaft seal walkabout Goldwing Technical Forum 5 01-29-2011 09:47 PM
Crankshaft Seal GL1000 SPC Goldwing Technical Forum 6 09-25-2010 03:31 PM
GL1100 crankshaft front seal deblak Goldwing Technical Forum 5 04-03-2010 08:13 AM
Crankshaft Seal on GL1100i rb7632 Goldwing Technical Forum 5 01-15-2010 07:57 AM
