post #1 of 11 (permalink) Old 05-23-2006, 12:31 AM Thread Starter
litfuse's Avatar
Model: GL1100I
A friend of mine has a front end wobble between 35 and 45. This is on an 89 gl1500.Any ideas.
litfuse is offline
post #2 of 11 (permalink) Old 05-23-2006, 03:14 AM
andy1800's Avatar
Model: 2008 GL1800, 16k miles
It's usually the tyre to blame. Unlikely to be a unbalanced wheel unless there is visible damage. Have a good look at that tyre.
andy1800 is offline
post #3 of 11 (permalink) Old 05-23-2006, 05:21 AM
Passed On, R.I.P.
Mohawk's Avatar
Location: Baldwinsville, Just Outside of Syracuse, New York, USA
Model: 09 Gl1800
Hi Litfuse,
Is this a wobble when he lets go of the handlebars?
Or is he hanging on to them? Even with one hand?
I have experianced this in two of my Wings.
But I had to be totally off the bars to make it happen.
And then most times a small bump or defect in the road makes it start.
This first time it happened on this Wing was after a long time in the saddle and I stood up on the pegs on a back country road and was stretching.
First thing I knew is the Wing started shaking and I droped back to the seat and had to use alot of strength and some front brake to get it back under control.
Scared the hell out of me.
My tires are fine, Checked Pressure and Front bearings and steering Head Bearing preload.
I dont have the Notch in the bearings some have found in thier wings.
Most of these problems were solved by mounting New Tires.
And I am going to do that. But I will ride awhile yet on these.
I just know this Wing is prone to wobble if I dont hang on to it.
So fore warned is Fore Armed.
Do a search on Wobble and you will find loads of info to help you guys sort out this problem.
Good Luck to ya.
Mohawk
95 Aspencade, Dressed to the Nines
Live to Ride - Ride to Live
My 4th Wing with 43 Years in the Wind Now
I have owned over 50 bikes now, This is the longest I have owned only one bike.
Prior USMC Sgt. and Vietnam Vet - Platoon Sgt. and D.I.
PGR Member since 2006 - Serving Those Who Served For Us.
The Native Americans found out what happens when you don't control immigration.
Mohawk is offline
post #4 of 11 (permalink) Old 05-23-2006, 11:38 AM Thread Starter
litfuse's Avatar
Model: GL1100I
I am leaning towards the tire also.I have checked everything and saw a small flat spot to the left of center line on front tire. It happens between 35 to 45 with lose hands on the handle bars.
litfuse is offline
post #5 of 11 (permalink) Old 05-23-2006, 11:40 AM
Get the steering head bearings torqued to 24 foot lbs. and your wobble will be gone if the bearings are OK. If the bearings are pitted then replace them and torque to 24 foot lbs. I have fixed 8 or 9 1500s this way.
Bing
Black 1800 No matter where I go there I am!
Binge is offline
post #6 of 11 (permalink) Old 05-23-2006, 11:47 AM
SilverDave's Avatar
Model: '85 GL1200 Aspy
¬*Adding a "Super Brace" to the front forks will¬* successfully mask the symptoms, quite often enough to make it of little concern [img]/forums/images/emoticons/emoticonsxtra/grinner.gif[/img], unless you do something like try to ride with no hands [img]/forums/images/emoticons/shock.gif[/img].¬* If you see no obvious flat spots, or unbalancing¬* of the front tire........ then replacing,and re-torquing the front steering bearings¬* will often get rid of most of the head shake...¬* ¬* ¬*SilverDave¬*[img]/forums/images/emoticons/emoticonsxtra/cooldj.gif[/img]
SilverDave is offline
post #7 of 11 (permalink) Old 12-15-2009, 02:41 PM
P-J
P-J's Avatar
Hello there,
Just added a 'brace' to the fork and, Lo and Behold, no more wobbly behavior. So, after indeed going through the tyre and springs routine, this finally may be it (?).
To be tested further.
Greetz,
P-J.
GL1500I 1991
GL1200I 1984
GL1100 Standard 1980
P-J is offline
post #8 of 11 (permalink) Old 12-16-2009, 01:34 AM
Psalmist's Avatar
Send a message via Yahoo to Psalmist
After 4 gl1500's I conclude most if not all 1500's will wobble at those speeds. Get the superbrace and new tire, problem solved.
Dino Hutchings
Fort Smith, AR
1999 pearl silver SE
Still trying to be pleasing before Jesus
Come to Arkansas and ride year round!
Psalmist is offline
post #9 of 11 (permalink) Old 12-16-2009, 03:04 AM
skoto1's Avatar
agree new tire first brace second.
PGR # 190570
cc permit
1988 1500 trike to be
1980 cb900 custom
gl 1988 1500 trike sold
2003 flhtuci sold
gl 1986 1200 trike sold
gl 1984 1200 trike sold
first bike cb 160 honda
to many to list in between
skoto1 is offline
post #10 of 11 (permalink) Old 12-16-2009, 09:47 AM
Lightin's Avatar
I too had an 89 gl 1500 that had the same wobbel at that speed just learned to keep bot hands on at tht speed but it mostly happed when coming down to that speed and not bad and only at that speed
John3:16
1st bike 125HD in 1969
250Honda Dream
750Honda
10 HD
89aspencade
1994 GL 1500 Trike
Past
91HD Maybe Trike project
Lightin is offline
GL1500 Front End Wobble rwurt Goldwing Technical Forum 8 09-14-2012 04:43 PM
GL1500 Front end wobble fixed yesterday awingandaprayer Goldwing Technical Forum 5 03-13-2012 02:14 PM
GL1500 front end wobble dale1500 Goldwing Technical Forum 20 03-02-2012 07:14 PM
Front end wobble, GL1500 Tom Johnson Goldwing Technical Forum 11 09-26-2011 07:45 PM
GL1500 Front End wobble John Chambers Goldwing Technical Forum 15 08-27-2011 09:36 PM
