post #1 of 25 (permalink) Old 12-28-2006, 08:42 PM Thread Starter
4evermetric's Avatar
So, what are the symptoms that your stator is going bad. Does it simply quit charging, or slowly quit charging, or start smoking, or what?
For what it is worth, my 87 GL1200 is charging at 15v+ at 2000 rpm, 13.5+ at idle, so is it okay?
Marty
Gun totin', motorcycle ridin', whisky drinkin', meat eatin' American. That's who I am...
2000 Valkyrie
1987 GL1200
1996 Motoguzzi Cali
Joined the Darkside-03.28.2010
Iron Butt Association, #38226
Robert Morris Lodge #97F&AM
4evermetric is offline
post #2 of 25 (permalink) Old 12-28-2006, 09:09 PM
Old School Guru
GLester's Avatar
Year: 2007
Make: Goldwing
Usually, it just quits charging or charges very little. Yours sounds fine. Check the 3 yellow wires coming out of the stator next to the front of the battery and make sure that the connector has been cut out and the wires sodered and heat shrink wraped to prevent it from burning the connector plug.
Gene
Gene Lester
Arkansas Chapter
Darksider #265
GLester is offline
post #3 of 25 (permalink) Old 12-28-2006, 09:14 PM
If you get any charging at all the odds are your stator is okay. Yours sounds pretty normal.
post #4 of 25 (permalink) Old 12-28-2006, 09:20 PM
Patch's Avatar
Send a message via Yahoo to Patch
Hey 4evermetric,
I have a write-up on my web site on how to check your stator. Here is a link:
http://www.goldwingsite.com/StatorTest.htm
As GLester said, make sure that your connector is cut out of the three yellow wires that is just forward of your battery. if the connector is not cut out, cut the wires just below and just above the connector, slide on 2 pieces of shrink wrap on each lower wire and solder each lower wire to an upper wire and then slide on 1 piece of shrink wrap and shrink and then repeat with the second piece of shrink wrap. Whne you get done, you will have 3 solid wires with double shrink wrap over each joint.
The object is to remove that white connector which is a common problem point on the 1200's.
If you are getting 15 volts at the battery with the engine turning 2000 rpm's, it sounds like it is fine.
Mine just went out in September and I went with the Poorboy Alternator Conversion instead of replacing the stator.
Chris & April Sanders
Patch is offline
post #5 of 25 (permalink) Old 12-28-2006, 09:23 PM
roscoepc's Avatar
I believe the stator isin asealed housing that is part of the engine case so it's doubtful if you'll see any smoke if it goes. I think also that if you loose one of the three legs it might be possible for the bike to charge @ 2000 rpms, 13v or so, but it won't charge at idle.
It sounds like you've got a good charging system though with it working at13.5-15v. Just make sure you check/hardwire/solder all the connectors between the stator and the regulator on that beast and that should take care of most of the headaches with the charging system.
Don
1985 Gl1200 Limited Edition
roscoepc is offline
post #6 of 25 (permalink) Old 12-29-2006, 01:54 AM
RD_Wingman's Avatar
Patch
The solder job U mention. Is what I've been told SHOULDBE DONEon my 76. Howard K. who use to write a thec. coulmn for GWRAA explained to me that that corrdided contacts at the stator are the source of some high feq. AC that was probibly the root of some electical gremlinsshowingup now and then. And that this also would dramacticly help to keep the stator from going bad.
GLester,"Howdeeey neihbor" where abouts in the Lone Star are U?? I'm in the Heights of Houston
RD
76 Gl 1000
78 450 SLC Benz
Only a motorcyle rider knows why a dog
sticks it\'s head out the window of a moveing car.
AND WAGS IT\'S TAIL!!!!!!!!!!!!
RD_Wingman is offline
post #7 of 25 (permalink) Old 12-29-2006, 03:15 AM
Silicon Sam's Avatar
Model: 1997 GL1500 SE
Hey RD, there's plenty of us Texans on this board. You need to come to one of our bi-annual Texas campouts. I come to Houston on work details from time to time. Not on the bike, but in my company van.
Raymond
Austin
1983 GL1100 Interstate Black
Silicon Sam is offline
post #8 of 25 (permalink) Old 12-29-2006, 08:49 AM
semerm's Avatar
Should this modification discussed be done for the 81 1100's as well?
Mark Semeraro
semerm is offline
post #9 of 25 (permalink) Old 12-29-2006, 03:45 PM
roscoepc's Avatar
Take a look at the connectors and see if they show any signs of getting hot. If so, solder them. If not,, I'd do them anyway for peace of mind!
Don
roscoepc is offline
post #10 of 25 (permalink) Old 12-29-2006, 03:54 PM
Yeah, I'm still here
Rudy's Avatar
Model: AmericanSportworks LMLSV
Send a message via Skype™ to Rudy
Sooo .... your answer is... yes then.
Rudy
"People give up their privacy for the chance at a $.10 off coupon!"
(quoted from conf. at ODNI)
Rudy is offline
symptoms of a bad stator nwtroutguy Goldwing Technical Forum 9 12-24-2010 10:43 PM
What are stator symptoms on '84 GL1200 ? justwannaride Goldwing Technical Forum 12 08-11-2010 07:37 PM
GL1100 symptoms of a bad coil? Damname Goldwing Technical Forum 9 05-05-2010 12:39 PM
Bad Stator outlaw21t Goldwing Technical Forum 5 03-27-2007 09:34 PM
Symptoms of bad Pulse generators? zonk3939 Goldwing Technical Forum 6 02-13-2006 12:07 PM
