post #1 of 9 (permalink) Old 03-06-2007, 02:11 PM Thread Starter
RB
RB's Avatar
Send a message via AIM to RB
I have been learning all about gl carbs and have decided to take mine off the bike and work on the ones that matter. So does it matter which side you pull them out from? Sitting on the bike left or right side? As I will have to remove the rest of my lower fairing and the crash bars so I only want to do one side if I can.
Can you take them out with the intakes attached?
I've got everything dettached, choke, throttle cables, air cleaner and the intakes loosened from the head side not the carb side.
I have been having this awful whistling or horn sound when I start my bike up and I think I may have found the problem it seems I maybe missing the idler screw from the #3 carb..I felt around under there and I don't feel anyting sticking out or even in the tube. But the bike started and idled just fine I even got the carbs synched so maybe it's broken off in there..but that's why I have decided to pull them.
I just got my rust converter, althogu it came with a cut in the bottle and leaked out some..We'll see how the rust converter people respond when I call them!
Is it me or am I having a run of bad luck???
1976 GL1000 RED rebuilt SOLD
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
1998 1500 SE..RIDING
FAIR WINDS,
RB
RB is offline
post #2 of 9 (permalink) Old 03-06-2007, 02:19 PM
Send a message via AIM to chskbak
the most come out on the left side, you gotta remove the air chambers on 1 & 3 carbs, the crash bars can stay on for this and the fairing too. it is a tight fit but if you wiggle it just right the slide right out
1980 GOLDWING INTERSTATE
chskbak is offline
post #3 of 9 (permalink) Old 03-06-2007, 02:22 PM
dan filipi's Avatar
Model: 1983 GL 1100 I
I think it's just you having the bad luck sorry to say.
But look at it this way, better to have this stuff come up now than somewhere out in the boonies with no cell service.
All 4 carbs come out together with the intakes attached but you have to remove the 2 right slider covers (right as sitting on the bike)
dan filipi is offline
post #4 of 9 (permalink) Old 03-06-2007, 06:41 PM
I find it easier to remove the 1100 carbs if I take the intake runners and the carb tops off the right side first. First take the intake runners off the right side carbs, then unbolt the left side runners from the head. With that done you can move the carbs a bitright to get the carb tops on the right side clear of the frame enough to remove the carb tops, pistons and spring. I don't like to leave the pistons in because it's easy to nick them and then you have more problems. So carefully lift them out of the right side carbs along with the springs. I usually mark the carb top and pistons with a marking pen so I can be sure to put them back in the same holes. Don't forget to remove the fuel line and the vacuum hose from #3 carb. At this point they can be wriggled out, it take some wiggling around but they will come out.
post #5 of 9 (permalink) Old 03-06-2007, 07:05 PM Thread Starter
RB
RB's Avatar
Ok, I got them out thanks for the advise. I actually only have to take off one of the air chamber tops and it wiggled right out air intakes and all.
What I found was not good..the bowls were all covered on the bottoms with rust a gummy red glue but more than just old gas. The biggy were the intake screens on the bowls they were packed tight with rust. NO wonder the bike won't run it was staved for gas. It all cleaned up now and just a matter of finding some air chamber diaphragms. Mine are all gummy and thin.
By the way The Rust Store people said no problem we'll send you out another bottle today.
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
FAIR WINDS,
RB
RB is offline
post #6 of 9 (permalink) Old 03-06-2007, 07:34 PM
ScottInNV's Avatar
Model: 76 GL1000
if you are looking for the air cut off valves, try www.siriuscoinc.com I got the cutoffs for my gl500 (same series carb, different application) through them for a reasonable price.
1976 GL1000 Nekkid!!
formerly had
1980 CX500
1981 GL500 SilverWing
1985 Honda GL1200 LTD
ScottInNV is offline
post #7 of 9 (permalink) Old 03-06-2007, 09:54 PM
fixit-now's Avatar
Did you get them off yet?
Just put mine back on , 3Rd time , had a O-ring in wrong.Just purrs now ,haven't adjusted any thing yet------ just sitting here listening to it !! got a big head now !!!!!!
Remember to keep the pointy end forward & the dirty side down ! Keep Safe
N7VAT
fixit-now is offline
post #8 of 9 (permalink) Old 03-06-2007, 10:43 PM
Fantastic fixit-now, When we going for another ride for breakfast?? That is one neat restaurant you took me to in Wickenburg.
We need to get Roger (RB) to go with us.
Join us for NASR10 "
SR10 "
Summer Rally #10 at
Forum Apps:
Android:
iPhone:
post #9 of 9 (permalink) Old 03-07-2007, 07:35 AM Thread Starter
RB
RB's Avatar
Yeah, guys rub it in..my bike is more pieces everyday. I keep taking things off and nothing seems to be going back on. I took some pics of the carb bowls what a mess! And the stuff around the final filter basket was amazing I actually scooped it out.
But I have nothing left to remove. Now It just rebuilding it all and putting it back together.
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
FAIR WINDS,
RB
RB is offline
Removing Carbs DWG Goldwing Technical Forum 5 10-27-2011 11:18 AM
Trouble removing carbs GL1100 sailorsubvet Goldwing Technical Forum 5 05-12-2010 08:44 AM
Help removing GL1100 Carbs Cougar Goldwing Technical Forum 18 06-07-2009 10:55 AM
removing carbs RB Goldwing Technical Forum 9 04-24-2007 08:22 AM
Removing Carbs nutwing Goldwing Technical Forum 2 11-12-2006 06:55 PM
