post #1 of 10 (permalink) Old 06-24-2007, 10:43 PM Thread Starter
Cajun66's Avatar
I've noticed a wobble in the front end while decelerating under 30mph and during slow speed turns. Everything I've checked is tight. But the tire is worn a little wierd. Would the tire be the likely culprit?
Saturday I hunted deer all day, and shot some ducks on Sunday.But all good things must pass away.
\"SIC TRANSIT GLORIA MUNDI\"
\"Thus passes the glory of the world\"
Cajun66 is offline
post #2 of 10 (permalink) Old 06-24-2007, 10:45 PM
toy4rick's Avatar
Hey there,
The more mine cupped, the greater the wobble. New tires will be here tomorrow.
Toy4Rick
It never rains in Southern California, so we ride
1997 SE Pearl White
toy4rick is offline
post #3 of 10 (permalink) Old 06-24-2007, 10:47 PM
retiredintime's Avatar
Yes...You need a new tire. Probably dipped out. Especially at the edges is why you notice it in turns. If you arn't carefull it could get bad enough to cause the bars to shake....
Bob..KF4GP
79 GL1000 46K
86 R80RT
90 K75RT
Garage won\'t hold any more!
retiredintime is offline
post #4 of 10 (permalink) Old 06-24-2007, 10:58 PM
Tattoo Taffy's Avatar
i feel a bit retarded at the moment, haven't experienced the shake yet
Tattoo Taffy is offline
post #5 of 10 (permalink) Old 06-25-2007, 05:47 AM
That's not unusual for you Taffy, you are far beyond experience.... in fact, I think you might be in the vaporous arena of 'med effect'....
Join us for NASR10 "
SR10 "
Summer Rally #10 at
post #6 of 10 (permalink) Old 06-25-2007, 11:33 AM
mikeatrain's Avatar
From my understanding the front end wobble is common on the wings. I haven't seen a post to fix it on here yet.
I've noticed thata new front tire will solve the problem for a while, but be prepared, it can return at anytime. Personally I NEVER let go of the grips with both hands at the same time! (When you let go you begin to slow down -the verything that causes the wobble). If you need to zip your jacket do it before you get on or stop to do it.
Mikeatrain
1983 GL1100 Interstate (SOLD)
Keeps on going and going and going
and still going under new owner
Then I found a 86 GL1200I to cheap to pass up.
mikeatrain is offline
post #7 of 10 (permalink) Old 06-25-2007, 12:09 PM
i have seen my brothers aspy do the head shake so bad i tought he ws going to plow that beast in! we were going down hill in a sub division and he let go of the bars to adjust his glasses.
broncbob is offline
post #8 of 10 (permalink) Old 06-25-2007, 12:13 PM
Patch's Avatar
Send a message via Yahoo to Patch
When I first got my 84 Aspy, it had a front end wobble just as you described. It was really bad. Bad enough that I was almost scared of loosing control.
I found my front tire to be worn and cupped. I ordered a new set of tires (rear tire was fine but I wanted a matching set) and installed them.
No more front end wobble.
Chris & April Sanders
Patch is offline
post #9 of 10 (permalink) Old 06-25-2007, 05:15 PM Thread Starter
Cajun66's Avatar
New tires are on the way. Thanks!!
Cajun66 is offline
post #10 of 10 (permalink) Old 06-25-2007, 06:06 PM
Dieseltu's Avatar
Its a well known issue. I get some too on my GL 1100. I have a .005 wheel side to side out of true. And a new tire and it does it.I let one go a bit to see how bad it could get. It definately flexes things a bit. From what I've read in Riding magazines. Its common on a lot of bikes. And concidered normal. The pros say dont take your hand off the handlebars , Ever.... Then it wont happen. Is all they ever come up with. If there is no mechanical issue.
82 Goldwing Interstate and a yard full of rolling junk.
Dieseltu is offline
99 SE front end low speed wobble? Bearings? streetglidexxx Goldwing Technical Forum 22 04-17-2010 02:45 PM
Low speed wobble after new front tyre.....gl1500 88 gabbysman Goldwing Technical Forum 3 07-11-2009 05:27 AM
front wheel wobble at low speed fishologist Goldwing Technical Forum 14 10-16-2006 10:06 AM
Front Brakes & Low Speed Wobble outlawearl Goldwing Technical Forum 4 05-10-2006 04:55 PM
Low speed front end wobble on 92; 1500 Lehman trike Papajoe Goldwing Technical Forum 4 04-17-2006 05:39 PM
