post #1 of 14 (permalink) Old 11-30-2007, 07:14 PM Thread Starter
Send a message via AIM to nad4664 Send a message via MSN to nad4664
my 1995 goldwing se radio will mute itself. when I try to 'unmute' it nothing works. push the mute knob in and out...nothing only mute stays on. it does this with intercom or just regular speakers. what is the source of thismute action? it will even do it sitting still in the garage???
nad4664 is offline
post #2 of 14 (permalink) Old 11-30-2007, 07:25 PM
Kind of sounds like the switching circuits are being "told to switch". That can be caused by moisture in the wrong places.
Has the bike really been soaked? Did you flood the handle bar switches when you were washing it?
I would look at the switches and remove the shelters from the bike and start tracing all of the wiring. Inspect the connectors between the handle bars and along the way to the radio unit.
There is also a possibility that a connector has gone "high joint". A term that means lost connection or has developed a very high resistance. That is usually in the connectors. Pull the connectors apart and push them back together. That will "wipe" the contacts cleaning them so they connect better.
Inspect everything, did a PO cut into the wiring harness and make some bad taps? If you see butt splices, be wary. Those are famous for giving trouble in low current circuitry.
Join us for NASR10 "
SR10 "
Summer Rally #10 at
post #3 of 14 (permalink) Old 11-30-2007, 09:01 PM
Yeah, I'm still here
Rudy's Avatar
Model: AmericanSportworks LMLSV
Send a message via Skype™ to Rudy
Turn off the CB and see if the problem goes away.
Rudy
"People give up their privacy for the chance at a $.10 off coupon!"
(quoted from conf. at ODNI)
Rudy is offline
post #4 of 14 (permalink) Old 11-30-2007, 10:28 PM
Just one of the guys
DougW's Avatar
If you have the headsets connected and the mute dial is set too sensitive it will mute thinking you are talking over the intercom.
Doug
DougW is online now
post #5 of 14 (permalink) Old 12-01-2007, 05:27 AM Thread Starter
I turned off the CB and the mute problem is solved. Thanks.
Hey, Merry Christmas from Houston, TX
nad4664 is offline
post #6 of 14 (permalink) Old 12-01-2007, 05:45 AM
Tattoo Taffy's Avatar
hehee, rudy rides again
Tattoo Taffy is offline
post #7 of 14 (permalink) Old 12-01-2007, 07:12 AM
Rudy's Avatar
I wish.
Rudy
Rudy is offline
post #8 of 14 (permalink) Old 12-01-2007, 07:41 AM
Good call Rudy.... I've noticed that once before but never use the CB so it didn't come to mind about the CB radio activating the mute circuits.
SR10 "
Summer Rally #10 at
post #9 of 14 (permalink) Old 12-08-2007, 01:41 PM
GERIATRIC MEMBER
Redwing's Avatar
Model: Neighbours 1800
[align=center]Hey nad4664 [shadow=aqua]You are Very Welcome to The Worlds Greatest Goldwing Forum.[/shadow] [/align]
[align=left]Please update your profile and insert your LOCATION.[/align]
[align=left][/align]
"Redwing"
Redwing is offline
post #10 of 14 (permalink) Old 12-08-2007, 02:33 PM
teacher's Avatar
Year: 1983
...................and Rudy strikes again!
~Butch~~~
1983 GL1100A,Wineberry
teacher is offline
Radio mute chiefcherokee Goldwing Technical Forum 11 08-18-2014 03:27 PM
GL1500 mute button is stuck on mute jeffy1500 Goldwing Technical Forum 4 07-03-2011 06:28 PM
Mute Button Bonnie General Motorcycle Discussion Forum 2 03-04-2011 11:03 AM
GL1500 mute wayhar Goldwing Technical Forum 2 09-16-2009 10:21 AM
radio stays on mute griffin Goldwing Technical Forum 6 07-19-2009 09:30 AM
