post #1 of 19 (permalink) Old 12-26-2007, 08:44 PM Thread Starter
jjanes's Avatar
Send a message via Yahoo to jjanes
I noticed my book says to change your brake fluid on a GL1800 at 12,000 miles.
I have never changed brake fluid in anything. Is this needed. And do any of you have any tips you can share. Thank you!
J M Janes
Having the time of my life on my Goldwing!
jjanes is offline
post #2 of 19 (permalink) Old 12-26-2007, 09:04 PM
bloodbought1's Avatar
We just finished changing the clutch and brake fluids on two 2005 GL1800's.
The first had 43000 miles and the second had 33000 miles. Both of these needed changing badly. The fluid was dark and had dirty settiments in the reservoirs. So I would change them.
JMHO
Bloodbought1
2007 Caberet Red GL1800
Dunlop Winter Sport M3 Runflat
205/55R-16
bloodbought1 is offline
post #3 of 19 (permalink) Old 12-26-2007, 09:11 PM
Wichita Scorpion's Avatar
Send a message via AIM to Wichita Scorpion
Hi jjanes. I find it best to pretty well follow the mfg. recommendations for changing brake fluid. Brake fluid does collect moisture over a period of time. In the olden days I have found pitting in the bottom of master and wheel cylinders on cars. Changing fluid every so often could have prevented this. The pitting in the metalis caused by water settling there. Just my thoughts.
Keith
Wichita Scorpion is offline
post #4 of 19 (permalink) Old 12-26-2007, 09:11 PM
Model: GL1500
I hope you have an easier time getting the air out of the lines of your 1800 than I am with my 1100
Served 823rd RED HORSE Unit \'83-\'88 USAF
\'Semper Ducimus\'
Red Knights Alabama Chapter 2
"Loyal to our Duty"
PGR Alabama Div.
1983 CX500 Custom
1981 GL1100 Standard
1982 GL1100 Aspencade
1985 GL1200 LTD
nightwizard40 is offline
post #5 of 19 (permalink) Old 12-26-2007, 11:14 PM
Keystone742's Avatar
Year: 1984
Model: Gl1200I
Don't let any brake fluid get on the paint, it will cause it to lift and peal. Best if you can cover everything with plastic and keep a bucket of soapy water handy.
1984 1200I
Keystone742 is offline
post #6 of 19 (permalink) Old 12-26-2007, 11:29 PM
I'm sure you'll get more guidance on this subject, but here's my .02 worth. Yes, change the fluid. Invest in a Might-Vac and suck the new fluid in from the bottom...don't get air in your system whatever you do. Cover the entire bike with a painters drop cloth and punch the master cylinders thru the plastic. Don't ask me how I know this. Add, suck, add, suck, and so forth until the new fluid arrives in the Mighty-Vac.
ronnielyons is offline
post #7 of 19 (permalink) Old 12-26-2007, 11:31 PM
English Bob's Avatar
Model: GL1800 2015 Red
I missed that! Guess I'll be doing mine in the spring.
English Bob is offline
post #8 of 19 (permalink) Old 12-26-2007, 11:35 PM
What's a Mighty-Vac and where do you get one?
post #9 of 19 (permalink) Old 12-26-2007, 11:59 PM
Harbor Freight (cheaper) or most any auto parts store. Ask for vaccum pump for bleeding brakes.
Keith
post #10 of 19 (permalink) Old 12-27-2007, 01:36 AM
Changing brake fluid every other year is my schedule. A very good inexpensive tool for brake bleeding comes from Harbor Freight. I have a Mighty Vac but prefer the metal tool since I don't like brake fluid on my Mighty Vac.
http://www.harborfreight.com/cpi/cta...emnumber=92474
The brake system on a motorcycle contains a very small amount of fluid compared to a car or truck. Since the fluid is designed to absorb water that gets into the system it doesn't take as much water to seriously contaminate the fluid. Once the water exceeds the absorbtion capability in the brake fluid corrosion begins inside the brake system. I find that every other year changing is sufficient in my damp area, the fluid that comes out is nearly as clean as fresh stuff. Besides reducing corrosiona biennial flush keeps the bleeder screws from freezing in place.
Take a good look at your master cylinders where the clutch andbrake leverspush on the piston rods. If you see any dampness there indicating fluid seeping out it's time to rebuild the masters.Fluid seeping out means water seeping in and that's bad news.
fluid change gl1500 kads Goldwing Technical Forum 3 03-06-2010 06:55 AM
clutch fluid change clive hammond Goldwing Technical Forum 4 03-31-2009 04:58 PM
Brake Fluid Change Paddygfw Goldwing Technical Forum 8 09-28-2007 08:08 AM
Brake fluid change smketr1100 Goldwing Technical Forum 18 05-12-2007 08:22 PM
Clutch Fluid/Brake Fluid/Coolant! 1986gw Goldwing Technical Forum 20 06-05-2006 12:44 AM
