post #1 of 5 (permalink) Old 06-11-2008, 10:41 PM Thread Starter
Hey, does anyone know how to get to the wiring harness inside the fairing. I was drilling a hole to run some wires through for a stereo. I drilled into the harness on the left side of fairing. If I remove the headlight can I get to it from there? Desperate for help. This is on a 1984 Gl1200 Aspencade with digital dash. Since I drilled into the harness now my tail lights do not work and it will barely run.
jusme is offline
post #2 of 5 (permalink) Old 06-12-2008, 12:55 AM
1984goldwing's Avatar
not sur what ara you drilled...but behind hadlight you can pull about a bucktfull of wiring out...then also on left side, in beneight poket..also look undr false gas tank...not that hard to remove the fals gas tank, so maybe by doing thos things you can find it
1984goldwing is offline
post #3 of 5 (permalink) Old 06-12-2008, 08:03 AM Thread Starter
I drilled into the harness right by the left side vent where the rubber boot connects the outside vent with the inside vent. I don't know how to get to it to fix it.
jusme is offline
post #4 of 5 (permalink) Old 06-12-2008, 09:27 AM
Mr. Fix it's Avatar
Model: GL1500 1990
This is bad news for you Jusme...
The harness feeds in frot the left side to the right side traveling over the headlight bucket.
To pull the harness out, you need to dis-connect all the accessories on the right side of the fairing. (and the left...)
You will have to remove both fairing pockets, dash hood which means the windshield has to come offto get to the accessories plus remove the headlight assembly to unplug the headlight.
You will have to remove the dash/instrument panel once the windshield is off which means you haveto remove mirrors..
Once all pieces are out of the way, the harness should pull out for the repair.
One tip, is to tie some string to the right side of the harness so you can pull it back through when re-installing it.
I wish you all the best in this adventure.
Mr. Fix it
Life is too short to have that big of a cow over the little things in life...
Mr. Fix it is offline
post #5 of 5 (permalink) Old 06-12-2008, 09:29 AM
Mr. Fix it's Avatar
Model: GL1500 1990
I forgot to mention that the radio & speakers have to come out for ease of removing the harness as well..
Check out the album Assembly of 1985 Goldwing for help and photos of the restore I did on my 85 last year.
http://community.webshots.com/user/eshopper12345
You may not find it too helpful but you will see what your bike looks like pulled apart!
1984 GL1200 Aspencade kesh Goldwing Technical Forum 18 12-07-2011 11:39 AM
1984 GL1200 Aspencade Fairing Schefner General Motorcycle Discussion Forum 11 10-10-2008 06:04 PM
1984 GL1200 ASPENCADE Dusty Goldwing Technical Forum 4 12-07-2007 06:24 AM
Intercom Wiring Harness for Driver 1985 GL1200 Aspencade jvortisch For Sale/Wanted Forum 8 11-23-2007 09:58 AM
1984 GL1200 aspencade jbunn For Sale/Wanted Forum 1 07-31-2006 11:55 PM
