post #1 of 14 (permalink) Old 09-21-2008, 03:13 PM Thread Starter
Crezz's Avatar
Hi all
My cruise control doesn't always work.
I press the on button (dash light comes on)and then when I press the set button (second light doesn't come on) it doesn't always set the speed etc.
Any ideas where to start looking
Adrian
2002 GL1800A2 Orange Aug 09. We Love It
RoSPA Gold Advanced Rider and Tutor
IBA UK
RBLR1000 2010, 2011. RBLR1500BBG 2012
Pain is Temporary, Pride is Forever
\'02\' GL1800 A2, My First 1800 Aug 09
\'88\' GL1500 (Japanese Import)My First 1500 May 2008 (Moved on to make room for above bike)
\'80\' GL1100 Fully dressed ex standard Apr 2006 (Moved on to make room for above bike)
\'81\' GL1100 DBX Feb 2001 (Deceased Apr 2006)
\'80\' CB250N 1982 (Gone)
\'79\' CB250N 1980 (Wrote off)
Crezz is offline
post #2 of 14 (permalink) Old 09-21-2008, 04:14 PM
Hi Crezz,
mine does the same thing, I have to push the clutch lever out with the back of my fingers, just so it goes all the way out, then the cruise will kickin when I press the switch again. I think my problems may be in the bushing in the lever. Others will be along with a more definitive answer.
But honey, I bet theres lots of people out in this rain today.
hoofman is offline
post #3 of 14 (permalink) Old 09-21-2008, 05:23 PM
SpiderBob's Avatar
I'm with you on the no work sometimes. Like today, pressed it in light on, but no "set" it wasn't until about 3 hours later that it finially "set". I can go for days and it will work correctly, the first time.
Spider Bob
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL
"If a man does not keep pace with his companions, perhaps, it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away."
Patriot Guard Rider
SpiderBob is offline
post #4 of 14 (permalink) Old 09-21-2008, 06:48 PM
Matt G's Avatar
Send a message via AIM to Matt G Send a message via Yahoo to Matt G
The manual has all the videos covering the cruise control system, including trouble shooting.
Current Goldwing:
1988 GL1500 Wings of Freedom
We tried voting with the Ballot box, When do we start voting from the Ammo box, and am I allowed only one vote ?
Matt G is offline
post #5 of 14 (permalink) Old 09-21-2008, 08:01 PM
Foodman's Avatar
Model: 2006 1800
You might try spraying the micro switches with contact cleaner while you work them.. If that doesn't work take a look at how much play you have on the clutch and brake levers.. The bushings there do wear and if they get loose the CC won't set....
Foodman is offline
post #6 of 14 (permalink) Old 09-22-2008, 09:37 PM
wolfeken's Avatar
My '94 does the same thing. Was out riding this weekend & pushed the Set button a couple of times & the light blinked & did not engage. Pushed outon the brake lever & it worked fine. Then when I hit a couple of bumps it disengages. One rider told me he replaced the microswitch on the hand brake & it took care of the problem. I haven't taken the time to do that yet.
wolfeken is offline
post #7 of 14 (permalink) Old 09-22-2008, 09:57 PM
Kyle's Avatar
Model: 2010
When your cruise does not want to engage, try applying the front brake and/or the rear brake. The connection sometimes wants to read as though you have the brakes applied which cancels the cruise and this will free up that circuit. Tap the front 1st (which is usually the culprit with mine) and try the cruise. Works every time for me.
2003 That is the fastest Red I've ever seen
2010 That is Black and has a Black Trailer on the Back.
Riding a 4 wheeler, 2 of them are on the trailer
My hair is white, my neck is red, my collar is blue.
Darkside #1721
2010 Rear-Bridgestone Driveguard 195/55R/16
2003 Rear-Goodyear Eagle Ultragrip 195/55R/16
Wild Rhino
Group of Ten (Those ten guys from Winnipeg)
AKA Wingerpeg
Kyle is offline
post #8 of 14 (permalink) Old 09-23-2008, 03:48 AM Thread Starter
Crezz's Avatar
hoofman wrote:
Hi Crezz,
Tried pushing out the levers with backs of fingers, made no difference, will need to investigate further
Thanks,
Adrian
Adrian
IBA UK
Crezz is offline
post #9 of 14 (permalink) Old 09-23-2008, 10:17 AM
Matt G's Avatar
watch the videos, it will save you time in trying to fix it.
Current Goldwing:
Matt G is offline
post #10 of 14 (permalink) Old 09-23-2008, 09:04 PM
SpiderBob's Avatar
OK, so this worked for my case. I took it all apart today. Used the contact cleaner on both sides. Did the micro switches and the switches.They goin and out so much easier now. I even did the lights, horn, hazard switch. And - it works. I turned it on and off today over 100 miles several times and it was consistently working. I hope I have no more problems with it. Oh, and for some reason it also fixed my surging that accompanied this problem. It stays steady give or take 3 miles an hour instead of 5 to 7 miles an hour.
Spider Bob
Patriot Guard Rider
GL1500 Cruise Control DaveClifton Goldwing Technical Forum 15 07-10-2012 11:22 AM
GL1500 CRUISE CONTROL JOHN OPPS Goldwing Technical Forum 8 07-31-2011 04:11 PM
GL1500 Cruise Control Help Redeye1620 Goldwing Technical Forum 8 06-24-2011 03:15 PM
GL1500 cruise control cycleman0622 Goldwing Technical Forum 3 01-31-2011 12:03 PM
GL1500 Cruise Control and Emissions control equipment IanB Goldwing Technical Forum 6 08-22-2006 05:04 AM
