post #1 of 5 (permalink) Old 04-13-2009, 01:34 PM Thread Starter
jackotom1954's Avatar
Hi, i own a 1996 gl1500se which has only done 16250miles, the bike has not been used for nearly 2 years and as i was testing the hazzard flashers the 5amp fuse blew, i replaced straight away but it blew again, does anyone know what the problem might be? the bike is standard apart from ring of fire fitted and light up eagle on front fender.
thanks dave.
jackotom1954 is offline
post #2 of 5 (permalink) Old 04-13-2009, 02:27 PM
Senior Guru
agnogel's Avatar
hi dave and welcome to the forum if you turn off the flashers and insert a new fuse will the fuse blow with only the ingation on
Peter
agnogel is offline
post #3 of 5 (permalink) Old 04-13-2009, 06:12 PM
Wichita Scorpion's Avatar
Send a message via AIM to Wichita Scorpion
Mine may be different from the 1996 GL 1500 SE.
1989 GL 1500 Electrical Troubleshooting Manual:
1. Accessory Fuse, #10 supplies powerfor the Hazard Lights. It is a 10 amp fuse.
2. My manual shows three 5 amp fuses:
Fuse # 1, Accessory Terminal, is for the optional added accessory terminals;
Fuse #9, Back Up,is hot at all times and supplies power for the memories, clock, radio, etc.;
Fuse #12, Tail/Ign.,supplies power to Bank Angle Sensor, Ign. relay coil, tail (main) relay coil.
I suggest that you check all your fuses and make sure the correct size fuse is in each slot.A couple of the fuses could have been switched over the years and maybe you now have an over fused circuit with a 10 amp fuse and an under fused Hazard circuit.
You could have a bad Hazard relay. The Hazard Relay and the Turn Signal Relays are both located under the trunk.
Looking at my schematics, I don't see anyway the Hazard lights can cause one of my 5 amp fuses to blow. Otherwise let us knowthe number of the5 amp fuse that is blowing.
Maybe someone with a 1996 will be able to give you better troubleshooting ideas.
Keith
Wichita Scorpion is offline
post #4 of 5 (permalink) Old 04-13-2009, 09:18 PM
I was just going to suggest the same thing that W.S. just said.
I think the 5 amp fuse you have belongs in a different circuit. It needs a 10 amp fuse for the Hazard lights and other accessories.
Join us for NASR10 "
SR10 "
Summer Rally #10 at
post #5 of 5 (permalink) Old 04-15-2009, 11:34 AM Thread Starter
Hi, thanks to all for the help i replaced the fuses now its fine,
thanks dave.
1996 GL1500SE inconsistant fire. pwhite24 Goldwing Technical Forum 29 09-09-2011 07:42 PM
Newbie with a 1996 GL1500SE bofus New Members Introduction Forum 12 03-01-2011 09:34 AM
1996 GL1500SE fmullins Goldwing Technical Forum 13 11-21-2010 04:47 PM
1996 GL1500se for sale in the UK mark on island For Sale/Wanted Forum 8 03-01-2010 03:07 AM
1996 GL1500SE. jackotom1954 For Sale/Wanted Forum 0 08-13-2009 03:03 PM
