post #1 of 11 (permalink) Old 04-16-2009, 04:03 AM Thread Starter
I am about to replace the pads front and rear on my GL1800, I have read the manual, and I have a question.
In the manual it says
[align=left]Push the caliper piston all the way in to allow installation[/align]
[align=left]of new brake pads by pushing the caliper[/align]
body inward.
I am assuming this means into the center of the wheel i.e on the front in the direction of the opposite caliper.
My question is how do you know how far and how hard to push?
Thanks in advance for any replies.
tanygaer is offline
post #2 of 11 (permalink) Old 04-16-2009, 05:48 AM
Kit
Kit Carson is offline
post #3 of 11 (permalink) Old 04-16-2009, 06:32 AM
Also put a coat of moly paste on the end of the pad where it contacts the bracket and on the back where it contacts the pistons and on the pin. This will help prevent them from making noise.
[SIGPIC]
post #4 of 11 (permalink) Old 04-16-2009, 10:30 AM
pinkpork's Avatar
when replacing the rear,,take care and make sure the pad is fully slotted home,,as the left rear one,,if its not fully home can catch on the rivets holding the brake disc,and cause them to wear,,,check by spinning your wheel afterwards ,,and listen for anything catching
Graham nsu quickly, suzuki 50, yamaha fs1e, yamaha 250yds7,
triton 750, trident750t150, norton commando 850 roadster,
honda750 f1, honda 750 f2, honda gl 1100, bultaco 250, kawasaki 500 h1, jpn commando ,25yr gap
2001 gl 1800 love it
pinkpork is offline
post #5 of 11 (permalink) Old 04-16-2009, 10:37 AM
Geordiemuppet's Avatar
Year: 1975, 2015
Model: GL1000, GL1800
Dave,
Give me a bell when you are ready to do it.
Paul
Paul
2015 GL1800 40th Anniversary Ladybug.
1975 GL1000K0
1992 ST1100M
Confusion will be my Epitaph....
Geordiemuppet is offline
post #6 of 11 (permalink) Old 04-17-2009, 12:37 AM Thread Starter
Thanks Guys, Gonna have a go at doing this later today,
tanygaer is offline
post #7 of 11 (permalink) Old 04-17-2009, 09:36 AM
On my 1500, I used the old pad along with a small c-clamp and to push the pistons back into the caliper untill they bottom out.
I had the front wheel off for tire replacement and noticed the pads were worn down quite a bit. I'm sure I could have used the same procedure as stated in the 1800 manual but a c-clamp works just as well.
Yes...remove some fluid if it has been topped off over time!
ddrumman2004 is offline
post #8 of 11 (permalink) Old 04-17-2009, 01:28 PM Thread Starter
Job done, abot two hours in total it took me and a am mechanically challenged, will have to pop out in the morning and give the old girl a spin, might take the bike out aswell....
tanygaer is offline
post #9 of 11 (permalink) Old 04-17-2009, 01:42 PM
GSMacLean's Avatar
Kit Carson wrote:
Wrap a good rag around the master cylinders, or just remove the brake fluid entirely and leave just enough to cover the intake of the master(that is what I do) so spilled fluid will not get on the bike. And as you push the cylinders the fluid will rise backwards.
Just push them in flush with the front body surface of the caliper body. Just flush is fine. that allows you to slip the pads in place.
You might want to look at them well, if corroded and very dirty, and lots of miles, might be time to take the calipers off and remove the pistons, clean them well and install new seals.
Why push all that dirty, worn-out old fluid back up into the master cylinder?
Just open the bleeder screw, put a hose on it and drape the hose in a container (to keep air from getting back in) then push the piston in. The nasty old fluid goes through the tube into the container. Once it's in, close the bleeder screw. The hose keeps air from getting back in in between pushing the piston and closing the bleeder. It also makes it a lot easier to push the piston in, because you aren't forcing brake fluid all the way up the brake line and through that tiny hole in the master cylinder.
Read my
GSMacLean is offline
post #10 of 11 (permalink) Old 04-17-2009, 02:55 PM
Please forgive me, I yield to a superior intelligence.
Kit
82 interstate brake pad replacement? dnnyjensen Goldwing Technical Forum 9 09-11-2012 10:09 AM
brake pad replacement 2001 goldwing maggiemae Goldwing Technical Forum 5 08-30-2011 11:38 AM
2006 GL1800 REAR BRAKE PAD REPLACEMENT vettster Goldwing Technical Forum 8 02-07-2010 07:39 PM
Brake pad replacement rhjiii46 Goldwing Technical Forum 4 06-20-2008 10:19 PM
1800 Brake Pad Replacement Littlejohn Goldwing Technical Forum 20 02-11-2005 03:11 AM
