post #1 of 9 (permalink) Old 06-24-2009, 02:31 PM Thread Starter
kevver's Avatar
Greetings All!
I hope one of you out in Wingland can help me?
After 9 years with a 1500 I have just aquired an 1100 Aspencade like the one I had in my youth!
But what I cant remember is;
Is it possible to take the dummy tank off without having to strip half the bike down? I seem to remember two bolts holding the front end on, but on this one (An American import) the same two bolts seem to be holding the fairing frame on as well?
Any help would be much apreciated as I wish to change the brake hoses for metal ones.
Best wishes,
Kevin Hogan,
Didcot UK.
kevver is offline
post #2 of 9 (permalink) Old 06-24-2009, 02:45 PM
Piled Higher and Deeper
sandiegobrass's Avatar
It is best to remove the lower fairing parts (three screws on each side) but it is possible to remove the two screws with a long extension with a 10mm socket through the fairing louvers, without removing the fairing parts...... in all there are 4 bolts on the fake tank... two at the front and two at the back after removing the seat..
AKA "Jim"
Have a Gold Wing? Please take the
2000 GL1500SE
1983 GL1100I
But formerly San Diego, Terra Haute, Aiken, Oak Ridge, Tonopah NV, Pasadena, and probably going back to Aiken..)
sandiegobrass is offline
post #3 of 9 (permalink) Old 06-24-2009, 02:59 PM Thread Starter
kevver's Avatar
Hi Sandiegobrass!
Many thanks for the prompt reply!
Will give that a go tomorrow.
Best wishes.
Kevver.
kevver is offline
post #4 of 9 (permalink) Old 06-24-2009, 04:02 PM
GSMacLean's Avatar
I agree, much easier to remove the fairing lowers.
Read my
GSMacLean is offline
post #5 of 9 (permalink) Old 06-24-2009, 04:25 PM
Silicon Sam's Avatar
Model: 1997 GL1500 SE
sandiegobrass wrote:
But it is possible to remove the two screws with a long extension with a 10mm socket through the fairing louvers, without removing the fairing parts......
Unless you have chrome shark gill add-ons to your lowers, then fugeaboutit....
Once you put the chrome gills on, there is no straight shot to the bolt anymore, go gotta take the lowers off then.
1983 GL1100 Interstate Black
Silicon Sam is offline
post #6 of 9 (permalink) Old 06-24-2009, 11:18 PM
gido's Avatar
It's a tight knuckle-dusting fit at the best of times. And when you put it back on watch that you don't disconnect some of the wiring near the front of the frame.
\'83 Wineberry Aspencade
owning and riding since \'62
You know you\'re getting old when your children insist that you report in during the course of your rides.
gido is offline
post #7 of 9 (permalink) Old 06-25-2009, 08:22 AM
GSMacLean's Avatar
I agree - it's the damn pneumatic hoses (too short!!) at the front, for the compressor controls, that drive me crazy. For that reason, a lot of the time, I end up removing the bolts, then just propping the back of the tank up with a screwdriver, and working underneath it, rather than removing it entirely.
Read my
post #8 of 9 (permalink) Old 06-25-2009, 03:30 PM Thread Starter
kevver's Avatar
Greetings one and all!
Many thanks to you all. fairing lowers removed and dummy tank followed!
Just waiting on the braided hoses now !
Kevver.
kevver is offline
post #9 of 9 (permalink) Old 06-25-2009, 06:16 PM
AndyB's Avatar
Year: 1983
Model: Gl1100 Interstate
I did not reinstall the front bolts on the dummy tank when I put it back on. I only have the ones at the back and I have no problem with vibration.
AndyB
1983 Black, gray, red custom wing bagger
AndyB is offline
tank rack on dummy tank williamchar General Motorcycle Discussion Forum 2 04-01-2011 07:02 AM
dummy Tank Removal GL1100 Pete Smith Goldwing Technical Forum 5 04-19-2010 02:31 AM
Gas Tank Removal For A GL 1100 Interstate Rockhound Rider Goldwing Technical Forum 8 06-12-2009 10:24 PM
1983 1100 gas tank removal Farmer536 Goldwing Technical Forum 7 03-08-2009 06:17 PM
Dummy Question about Dummy Tank! BigDogDaddy Goldwing Technical Forum 5 11-23-2007 09:38 AM
