post #1 of 4 (permalink) Old 06-28-2009, 09:50 PM Thread Starter
knute's Avatar
A co-worker can't get spark on his 250 Yammer enduro, CDI?, stator? can they be bench tested? just wondering if anyone out there has dealt with this. Thanks.
My Father always told me,"Don\'t sweat the little $h!*." Words to truly live by. My past-80\'GS 750L(not bad),85\'V65 Magna(WOW!),81\'750 Nighthawk(YUK!carbs kept goofin\'up),84\'V65 Magna(once again,WOW!),81 Maxim(GREAT BIKE!),and lastly,89\'GL 1500.
knute is offline
post #2 of 4 (permalink) Old 06-28-2009, 10:20 PM
Sprdtyf350's Avatar
What year is it? The 250 has points. The 400 has the CDI. I would start looking at wiring first.. Like the kill switch if it has one.. Or make sure the points are opening..
1983 GL1100 Aspencade
1975 Yamaha RD350 x2
1972 Yamaha DT2 250 Enduro
1971 Yamaha RT1B 360 Enduro
1973 Yamaha RT3 360 Enduro
1986 Honda XL600R
Sprdtyf350 is offline
post #3 of 4 (permalink) Old 06-28-2009, 10:35 PM Thread Starter
knute's Avatar
I believe it's a 76' model.
knute is offline
post #4 of 4 (permalink) Old 06-28-2009, 10:49 PM
Sprdtyf350's Avatar
Well a 76 should have points. It could be anything. I would have him pull the cover over the magneto and see if it is full of water, or really corroded. I have seen spark plug caps go bad, points worn so they did not open, etc. Standard stuff. Those systems are pretty bulletproof and the main components don't really fail very often. So I would look at the obvious like kill switch, ignition switch, point gap, condenser that may have gone bad, spark plug cap, stuff like that.
1986 Honda XL600R
I got spark, got GL1500 running! No Power or Spark problem FIXED!!! kemoloney Goldwing Technical Forum 211 06-24-2012 10:27 PM
GL1100 rusty spark plugs/spark plug wires? machineman2101 Goldwing Technical Forum 5 04-03-2012 06:01 PM
My 250 cc two wheeler monkeytrucker Miscellaneous Forum 5 03-21-2012 09:40 PM
$250 Goldwing Fritz_The_Cat General Motorcycle Discussion Forum 4 11-10-2009 06:54 PM
honda 250 welsh winger General Motorcycle Discussion Forum 1 02-27-2008 06:19 PM
