post #1 of 4 (permalink) Old 09-28-2009, 05:12 PM Thread Starter
Send a message via AIM to flyingcopters Send a message via MSN to flyingcopters Send a message via Yahoo to flyingcopters
Hello fellow members. I am new to this site, and a new Gold Wing ower. A Harley crossover. My back sure feels better with my smooth ride!
Question: Do you have to remove the front forks to change the oil and the springs? The service manual says that they have to be removed and that a special tool has to be used, called a Fork Bolt Assembly tool, serial number 07KMF - MT2 - 0300, which is also to remove the caps.
Is it cheaper to buy the tool and do it myself or take it to the Honda Dealer and have him do it?
My new bike is a 1993 Interstate. It looks like a lot of work to change the oil and the springs, according to the manual.
Any advice would be greatly appreciated.
Thanks!
Brian
flyinbrian
flyingcopters is offline
post #2 of 4 (permalink) Old 09-28-2009, 05:24 PM
Senior Guru
agnogel's Avatar
Hi brian no you dont have to remove the forks all you do is remove the two hex bolts in the top of the forks be carfull the cap might hit you when the spring jumps up make sure the bike is on the center stand, for the oil there is a drain plug in the end of each fork just remove the roter covers if fitted to get access its important to fill with the right amount of oil not to much and the right leg takes a little more than the left i cant remember the quantaties but you have it in the manual
Peter
agnogel is offline
post #3 of 4 (permalink) Old 09-28-2009, 05:58 PM
Nobody
kennyd's Avatar
You just asked this question here:
http://www.goldwingfacts.com/forums/forum1/79472.html
2005 GL1800
kennyd is offline
post #4 of 4 (permalink) Old 09-28-2009, 07:21 PM Thread Starter
What do I use to remove the two hex bolts?
flyinbrian
Front Forks 1993 GL 1500 SE dyoung For Sale/Wanted Forum 2 03-11-2010 08:58 AM
Rebuilding front forks on a 1500 BikernDiver Goldwing Technical Forum 7 04-20-2009 01:30 PM
Front Forks GL 1500 dyoung Goldwing Technical Forum 1 08-10-2007 03:11 PM
Front Forks for '98 Goldwing GL 1500 delly For Sale/Wanted Forum 0 12-19-2006 03:22 PM
88-1500 front forks oil Dman Goldwing Technical Forum 5 09-02-2005 12:00 AM
