post #1 of 17 (permalink) Old 10-22-2009, 11:16 PM Thread Starter
Hi,
I have an 1989goldwing and needed some instruction on winterizing. Specifically, how do you drain the carb bowls?Are they accessible by just taking off the side covers?
Thanks.
Bobm is offline
post #2 of 17 (permalink) Old 10-23-2009, 06:02 AM
Graham B's Avatar
You need a flashlight (Torch) and a VERY long flat blade screwdriver. From the front of the bike look for the gaps in the grill between the radiators.
Shine your light into that gap and, in the murk, tubes and cables you will find a screw at the bottom of each carb. Loosen each screw (1-2 turns) and watch the fluid go all over the floor.
Best done with the engine cold.
Don't forget to retighten the screws afterwards.
Graham
1990 GL1500 SE
Graham B is offline
post #3 of 17 (permalink) Old 10-23-2009, 07:06 AM
GLGREZMONKI's Avatar
Location: Bedford (Halifax Regional Municipality), Nova Scotia, Canada
Model: SE 1500
Hi Bobm.........maybe it would be easier to use a good quality fuel stabilizer . Stabilizer is generally able to prevent fuel from "rotting" for up to six months. Simply put the appropriate amount in the fuel tank (follow the instructions on the bottle) and run your engine for about 10-15 minutes which will fill the carb bowls with the treated fuel and you are done. Will also potect the fuel tank and will make spring starting easier.A brand known as STABIL has been used for years with excellent results..........GM
GLGREZMONKI is offline
post #4 of 17 (permalink) Old 10-23-2009, 07:57 AM
Token Canuk
96aspencade's Avatar
Model: 1996 SE
Or you could try some Sea Foam
Sea Foam info
Retired Paramedic - 35 yrs
DD # 1138
30,000 miles - Formosa,
'96 GL 1500 SE - 260,k km
'83 Shadow 500
'70 Kawasaki KE-125
'?? Suzuki 80
96aspencade is offline
post #5 of 17 (permalink) Old 10-23-2009, 08:43 AM
Just another ORF!
Dusty Boots's Avatar
Model: 92 1500 Aspencade
Yup, I add some Sea Foam to the gas tank and run her for a few minutes, before shutting her off and putting her away(with a full tank of fuel)for the winter.
Come spring time, she fires right up.
- just another Rider
Dusty Boots is offline
post #6 of 17 (permalink) Old 10-23-2009, 08:47 AM
Hickey's Avatar
Model: GL1500 SE
Also you don't have to worry about your gasket drying out and cracking. SeaFoam for my also.
Hickey
70 Harley, 74 & 77 Suzuki, 86A Goldwing, 99SE Goldwing
ALR POST 820
PGR MEMBER
Hickey is offline
post #7 of 17 (permalink) Old 10-23-2009, 10:24 AM
lionelgo50's Avatar
I'm not sure if this is a good idea or not,but my brother drains his by closing the petcock from the tank and starts his bike and lets it run out of gas so his float bowls are empty. I would think it may cavitate his fuel pump...
Dave
Ride Safe and Ride Often, Keep the Shiny Side up and Many Happy Miles and Smiles.
In God We Trust; All Others Must pay Cash!!!
Current Goldwing 2010 Gl1800 Trike Caliente Red
1997 GL1500 SE Pearl Sonoma Green
Other Rides
2012 Harley Davidson Heritage Softail
2007 Honda 110cc
Past Rides
2 1985 Goldwing Aspencades, 2006 Harley Davidson Sportster 1200, 2006 Goldwing Navi, 2007 Honda Rebel, 1994 1500cc Goldwing Interstate
lionelgo50 is offline
post #8 of 17 (permalink) Old 10-23-2009, 10:40 AM
I've never drained my carbs. Just fill or fill and add stabil. Same results next spring, it starts a litle hard unless I squirt some carb cleaner in the intake. That extra squirt helps a lot.
sfruechte is offline
post #9 of 17 (permalink) Old 10-24-2009, 01:18 PM Thread Starter
Thank you everyone for the tips. Very helpful!
Bobm is offline
post #10 of 17 (permalink) Old 10-25-2009, 12:35 PM
The Irish Crew
FitzAl's Avatar
Model: GL1100 Interstate
I don't drain mine either because they can still fur up inside. Stabil is a better idea IMHO.
Alan Fitzpatrick.
FitzAl is offline
GL1500 WINTERIZING HELP walnut Goldwing Technical Forum 2 09-16-2012 05:00 PM
Altitude or poor winterizing? GL1500 wooddy88 Goldwing Technical Forum 10 03-13-2011 07:33 PM
Winterizing 96aspencade General Motorcycle Discussion Forum 5 11-23-2009 02:14 PM
winterizing phatty of 2 Goldwing Technical Forum 18 09-10-2008 05:00 AM
Winterizing zonk3939 Goldwing Technical Forum 22 10-16-2005 06:15 AM
