post #1 of 30 (permalink) Old 10-24-2009, 12:19 PM Thread Starter
don oller's Avatar
Model: GL1800 AND KAWA.NOMAD
Send a message via MSN to don oller Send a message via Yahoo to don oller
I HAVE CHECKED FOR VAC. LEAKS TA SENSOR ,RUN SEA FOAM THRU SEVERAL TIMES CLEANED THE CARBS BY SPRAYING INTO TOP OF CARBS .WITH CARB CLEANER NOTHING SEEMS TO WORK BIKE HAS 97000 MILES ON IT .BEEN TOLD THAT SOME OF THE 88 WINGS HAD THIS PROBLEM . AND HONDA HAD A FIX BUT NO LONGER OFFERS IT .DOES ANY ONE KNOW ABOUT IT. THE IDLE STILLS GOES UP AND DOWN 500 RPM 900 TO 1500 RPM.
Don & Marion Oller
chapter directors FREEDOM WINGS chapter F
American gold wing association vice president
TN state director
region director south east usa AGWA
FREEDOM WINGS IS A CHARTERED CHAPTER 0F THE AMERICAN MOTORCYCLE ASSOCIATION
don oller is offline
post #2 of 30 (permalink) Old 10-24-2009, 12:21 PM
William_86's Avatar
Model: GL1500 Aspencade
i have heard that turning the idle adjustment in and out fixes this problem in some 1500s.
William_86 is offline
post #3 of 30 (permalink) Old 10-24-2009, 12:22 PM Thread Starter
don oller's Avatar
TRIED THAT NOPE STILL SAME
Don & Marion Oller
TN state director
post #4 of 30 (permalink) Old 10-24-2009, 01:28 PM
Who the heck cares?
rayworx's Avatar
Model: 88 GL1500
Don...
97k miles sounds like it gets driven on a frequent basis but the question HAS to be asked:
Has the bike been in storage in the immediate past? and do you winterize the bike during the PMS season?
Fuel starts to turn bad after 2 months and can cause build up inside the carb jets. Since the idle jet (or called the slow speed jet) is the smallest jet in inside diameter it's also the very first to be effected by yearly buildup. Sometimes fuel additives will work.... sometimes they won't. When they don't work then it's time to remove the carbs, open them up and clean them out. Obviously it's also the time to check the float settings; adjust if needed and to check the vacuum hoses that are under the carbs and almost impossible to get to if the carbs are in place.
The next suggestion is those previously mentioned vacuum hoses. They are real hard to diagnose and one in particular is notorious to fail.... it's a u-shaped hose that connectsthe intake manifolds and they are directly under the carbs and the rubber mat shield.
Good Luck.
Ray
88 GL1500
rayworx is offline
post #5 of 30 (permalink) Old 10-24-2009, 06:15 PM Thread Starter
don oller's Avatar
the bike has set some and one dude tried to work on them and did not know what he was doing i had to ck. every hose so they are right as far as i can tell have not removed the carbs was hoping i would not have to do them.
Don & Marion Oller
TN state director
post #6 of 30 (permalink) Old 10-25-2009, 12:46 AM
Busdriver
busdriver's Avatar
Year: 1990
Model: GL1500, 166,000 KM
Could be cracks in the carb to intake rubbers.
You need to spray some starter fluid onto them while the engine is running and see if the idle increases.
busdriver is offline
post #7 of 30 (permalink) Old 10-25-2009, 10:45 AM
or use unlit butane torch, or WD-40
Join us for NASR10 "
SR10 "
Summer Rally #10 at
post #8 of 30 (permalink) Old 10-26-2009, 01:58 PM Thread Starter
don oller's Avatar
tried all the above still got problem
Don & Marion Oller
TN state director
post #9 of 30 (permalink) Old 10-26-2009, 03:19 PM
Sounds vacuum related to me. Hoses, intake manifolds, slide diaphragms.
I think you are going to have to pull the carbs.
post #10 of 30 (permalink) Old 10-26-2009, 04:11 PM Thread Starter
don oller's Avatar
ithink you may be right.
Don & Marion Oller
TN state director
1988 gl 1500 stumbles at idle and acceleration jpcruiser Goldwing Technical Forum 20 06-09-2012 12:42 PM
1988 gl1500 wom't idle HELP!!!!!!!!!!! Dave549 Goldwing Technical Forum 8 10-07-2010 07:51 AM
GL1500 1988 patrickfitzgerald Goldwing Technical Forum 5 04-12-2008 08:52 PM
Interchangeable body parts 1988 GL1500 and 1991 GL1500 Aspencade guywithsidecar Goldwing Technical Forum 2 08-12-2007 04:01 PM
1988 gl1500 chip Goldwing Technical Forum 7 10-24-2004 06:31 PM
