post #1 of 4 (permalink) Old 11-23-2009, 10:13 AM Thread Starter
Some observations on head shake. First I am no engineer, just very experinced rider. I have approx 500,000 miles and 45 years on every thing from dirt bikes to goldwings.
It,s been my experiance that when I had a flat on the rear at speed ,upon slowing down thefront went to shaking violently from about 40mph on down Also on my goldwing the final drive destructed,the first symptoms was a high pitched whine that sounded like it came from the dash area.Latter it sounded like I had a FRONT bearing grinding . After tearingit apart three times to check still didnt find anything wrong, then went to the rear and checked under the final drive and saw ground metal. The point I am trying to make is that sound and wobbles are transmited from therear. Also my 01 had head shake from the first monthI bought it new. I now have almost 100,000 miles on it and no head shake. In trying to solve it I changed types of tires and brands,new steering bearings, changed front springs,sometimes after a new tire the wobble would go away for aperiod of time. Also replaced both wheel rims. At 62,000 miles I had to change the rear brake rotor the wobble stopped, This doesn't make sense unless the rotor was out of balance. I think the reason that some rear tire changes stop the head shake is that they were balanced better than others also when mounting, the tire is placed at a different point on the rotor either compounding or correcting the out of balance rotor. Sorry if this seems rambling, but don't discount the fact that seeminglyfront end problems may be in the rear Sledge
sledge72653 is offline
post #2 of 4 (permalink) Old 11-23-2009, 02:13 PM
clpete's Avatar
Resently I have noticed a small wobble in the front. It only happens when I am riding at about 30 to 40 mph and the road has a dip or bump running the same direction of the road. Since it only happens when the road is defective I guess it may just be the road, but I never noticed it before.
Someone told me that it's most likely my front tire, so I ordered a new one.
clpete is offline
post #3 of 4 (permalink) Old 11-23-2009, 03:41 PM
Gregarious Greeter
SETHAN12's Avatar
Model: GL 1800
I rarely experience wobble of my front wheel and when I do I think is due to road surface.
Yesterday is for memories!
Today is for making memories!
Just livin\' the dream!!!!!
Honor above all else!!!!!
SETHAN12 is offline
post #4 of 4 (permalink) Old 11-23-2009, 07:47 PM
You are right about it could be either the front or the rear. Out of balance or out of round or looseness in the steering or swing arm can cause it. I don't see how a rotor could cause it because it does not have much mass and can't be out of balance by much but stranger things have happened. I had a shake in my 1800 until I quit using radial front tires. Now nothing will cause it to shake except 1 time when I had to nail the brakes hard at high speed to avoid being hit but it stopped as soon as I got off the brakes.
[SIGPIC]
GL1800 front end wobble beachbuddy0253 Goldwing Technical Forum 14 10-01-2015 02:15 AM
Front End Wobble GL1800 vernw Goldwing Technical Forum 16 10-05-2010 12:47 PM
Front end wobble GL1800 Buzzmoe2 Goldwing Technical Forum 6 09-23-2009 11:01 PM
Front end GL1800 wobble Grizzz Goldwing Technical Forum 23 05-03-2008 04:45 PM
Front end wobble DigbyODell Goldwing Technical Forum 31 08-13-2006 09:40 PM
