post #1 of 12 (permalink) Old 11-29-2009, 03:21 PM Thread Starter
I did a lot of trouble shooting and thought it was a sticking start/reverse button. I cycled the start/reverse button numerous times and the headlight came back on. But when I went to start it again the headlight wouldn't work again. I have repeated this process numerous times but really need to fix the problem. Any ideas?
Bob
wingnut59 is offline
post #2 of 12 (permalink) Old 11-29-2009, 04:05 PM
johnmac's Avatar
It may be the Hi-Lo switch. I have had the same problem with mine.
1996 GL1500 SE
Past bikes
1985 Aspencade 1200
1978 Honda GL 1000
1974 Honda 350 Four
1974 Yamaha TY 250 Trials
1973 Yamaha 360 RT3
1971 Honda SL 100
1968 Honda Trail 50
3 1/2 HP mini bike
johnmac is offline
post #3 of 12 (permalink) Old 11-29-2009, 04:09 PM
AspectOne's Avatar
Send a message via MSN to AspectOne
Dis assemble your switch housings and clean them with contact cleaner would be first step I would take
AspectOne is offline
post #4 of 12 (permalink) Old 11-29-2009, 05:39 PM Thread Starter
Thanks AspectOne. I will give that a try. Have a great night.
post #5 of 12 (permalink) Old 11-29-2009, 10:00 PM
The fact that fiddling with the switch helps make me agree with Aspect One.
Keep in mind there are lots of little parts inside that switch. Keep track of where things go.
Mine required disassembling the actual button and re-working the spring. With 115k miles, you may need to do the same.
post #6 of 12 (permalink) Old 11-30-2009, 07:20 AM
SA Wingrider's Avatar
Model: GL 1800 Trike
Yip, Your problem will be solved by just opening the switch and clean it out with a electric contact spray.
Johan.
SA Wingrider is offline
post #7 of 12 (permalink) Old 12-02-2009, 12:42 PM Thread Starter
Okay.....Inside the switch housing is interesting. There is a "ball shaped" piece of metal with a wire attached to it just under the "set/decel" switch housing. It makes contact with a small circular metal spot that is part of the start/revese switch. It looks like this "ball" is only held in place by pressure from set/decel switch housing. Seems like a poor design to me if it is. I couldn't locate an illustrated breakdown pf the switch.
I also found that when the switch sticks I can pull it towards me and the Head light comes on and stays on unless I cycle the switch again.
post #8 of 12 (permalink) Old 12-02-2009, 01:05 PM
Got to be a spring involved. You sure the attached wire isn't spring steel?
Can you post a pic?
post #9 of 12 (permalink) Old 12-02-2009, 01:22 PM
rgbeard's Avatar
I thought intermittent/flashing lights were a feature - not a bug.
My name is Rusty. I'm an enthusiast of things that ride, drive and fly.
IBA: 63413
rgbeard is offline
post #10 of 12 (permalink) Old 12-02-2009, 01:23 PM
grambo's Avatar
check the big connector behind rt knee panel
91 GL1500
91 Electraglide
Ask the wrench god 1st!!
grambo is offline
'82 1100i - Headlight not working Stecker1100 Goldwing Technical Forum 12 09-12-2012 01:30 PM
headlight quit working knute Goldwing Technical Forum 3 07-08-2008 06:07 PM
Headlight not working Wicketdog Goldwing Technical Forum 14 03-31-2008 03:25 PM
Headlight is not Working!! prizmatik Goldwing Technical Forum 8 01-16-2007 07:24 AM
Headlight No Working Roberts1500 Goldwing Technical Forum 10 01-04-2006 11:10 AM
