post #1 of 7 (permalink) Old 12-13-2009, 01:43 PM Thread Starter
I have a 96 1500, I have been noticing lately that when I drop to an idle I have about a 200 rpm surge and then back to a normal idle. It does not seem to hurt anything but I would like to know what is causing it. I have been running seafoam in the last few tanks.
Jeff
jeffo is offline
post #2 of 7 (permalink) Old 12-13-2009, 02:55 PM
Senior Guru
agnogel's Avatar
hi jeff turn the idel ajuster in the gas cap door up and down a few times and set to normal idel 700rpm PLUS OR MINUS 50 see how you get on
Peter
agnogel is offline
post #3 of 7 (permalink) Old 12-13-2009, 03:38 PM
grambo's Avatar
maybe your carb boots are hard..spray around in there and see...for a vac tube going south?
91 GL1500
91 Electraglide
Ask the wrench god 1st!!
grambo is offline
post #4 of 7 (permalink) Old 12-13-2009, 04:49 PM
mikef's Avatar
Model: Aspencade
Agreed. Try leaving it off and open the throttle a bit, to make it easier to turn, especially if you haven't done it for a while, or ever.
Finally, old enough to know better. Just need some common sense now......
Patriot Guard Rider
1986 GL1200 Aspencade
1993 GL1500 Aspencade
1985 GL1200 Aspencade
1985 Suzuki Madura 700
1973 Honda 350CB
1965 Honda 50
mikef is offline
post #5 of 7 (permalink) Old 12-13-2009, 05:56 PM
A d m i n i s t r a t o r
D-Rod's Avatar
Model: 1994 Aspencade
There is a thumbscrew under the gas tank door. People have found that if you turn the screw back and forth and then set the idle it seems to clear up the surging. Move it back and forth once in a while when you get gas and that should keep it free. If you have a hard time turning it, try turning the throttle a little and hold it open while you adjust the thumb screw.
Dennis
Join me on facebook Dennis D-Rod Ruda, Hamburg, New York
Button Lady's book website:
D-Rod is offline
post #6 of 7 (permalink) Old 12-13-2009, 06:43 PM
Lost on this *****
Winger77's Avatar
Model: 1997 Aspy
Send a message via AIM to Winger77
If the idle adjustment screw does not fix the surge,, it could also be the choke is stuck slightly closed.
The things I liked,,,,I\'ve tried em twice!
You have to be a little Crazy,,,,,, or else you\'ll go Insane.
Winger77 is offline
post #7 of 7 (permalink) Old 12-14-2009, 08:44 PM
Guest
Posts: n/a
Check all the vaccum lines mine did the same thing and i had to replace almost all the vaccum lines.
1996 gl1500 RLeeB Goldwing Technical Forum 5 05-12-2012 10:05 AM
GL1500 terrible idle surge AQUAMAN Goldwing Technical Forum 29 04-30-2012 12:21 PM
1996 GL1500SE has dramatic surge vincent52100 Goldwing Technical Forum 6 06-22-2011 05:43 PM
RPM Surge While In Third Gear N5HQ Goldwing Technical Forum 3 08-06-2009 01:41 PM
RPM surge and MPG question. Aeiceman Goldwing Technical Forum 40 03-10-2009 05:07 PM
