post #1 of 18 (permalink) Old 01-02-2010, 04:50 PM Thread Starter
As a new member I've looked at the posts on this topic but have not found my answer. The cruise control on my 1992 GL1500 SE will come on but won't set at any speed. I've checked all the switches and they seem to be ok. I replaced the sending unit behind the speedometer but that didn't help. Anyone have any ideas? Thank you.
maccam is offline
post #2 of 18 (permalink) Old 01-02-2010, 04:59 PM
wexy's Avatar
Most common fault is the levers ,ie clutch or brake lever .There are micro switches on them for the cruise and either the owners replace the original levers with chrome ones or the original levers wear and do not operate the micro switches ,Check the levers and the rear foot brake .. Ciaran
CIARAN (pronounced Keeron)
yes it is Gaelic
wexy is offline
post #3 of 18 (permalink) Old 01-02-2010, 05:54 PM
cntryboy1289's Avatar
I recently found my foot brake was preventing mine from setting. I have floorboards and the way my foot was resting against it was the cause. Make sure you push out on the hand brake and use your toe to lift up on the foot brake and see if it sets for you before you do anything else.
Like ol\' Hank said, a cntryboy can survive!!
Patriot Guard #169835
in the cage
on the bike
cntryboy1289 is offline
post #4 of 18 (permalink) Old 01-02-2010, 06:53 PM
junior moderator
If it's not the switches it is probably a bad vacuum line to the actuator.
[SIGPIC]
post #5 of 18 (permalink) Old 01-02-2010, 06:57 PM
grambo's Avatar
left clutch lever might need a tube spacer...left switch needs to be normally open and you can use a piece of fuel line and slip it on the post to hold it open
91 GL1500
91 Electraglide
Ask the wrench god 1st!!
grambo is offline
post #6 of 18 (permalink) Old 01-02-2010, 07:29 PM
When you say the cruise control comes on I assume you mean the cruise on light illuminates but the 'Set' light doesn't. There's another switch involved with the cruise control, it's the throttle shut off switch. It's located down by the carbs where the throttle cables attach. All told counting the clutch switch, front brake switch, rear brake switch and the throttle switch there are four switches that have to work properly for the cruise to be set. If all those are working right then the problem could be in the wiring to the ECU which is the brains of the outfit. I don't think a broken vacuum line or bad vacuum control solenoids would cause this problem. If it was caused by those two failures I believe the 'Set' light would still light up even though the cruise control would still fail to work.
post #7 of 18 (permalink) Old 01-02-2010, 07:37 PM
junior moderator
You are correct.
[SIGPIC]
post #8 of 18 (permalink) Old 01-03-2010, 12:41 AM Thread Starter
Thank you all so much for your quick replies. Some of the suggestions I've tried, but other suggestions I hadn't considered or had not tried. Thank you again.
maccam is offline
post #9 of 18 (permalink) Old 01-03-2010, 01:41 AM
Foodman's Avatar
Model: 2006 1800
There is 1 Micro switch that works off the foot break that's way down by the lower frame and exhaust pipe on that side.. It's hard to see let o lone get to.. There are only 2 screws that hold it in place.. If they just come lose it will keep the cruise from setting...
Foodman is offline
post #10 of 18 (permalink) Old 01-03-2010, 02:34 AM Thread Starter
Thank you Foodman....that is another suggestion that I will try.
maccam is offline
GL1500 Cruise Control Problems efd33 Goldwing Technical Forum 7 05-18-2012 11:20 PM
GL1500 cruise control problems and lghts...why? pippomaranga Goldwing Technical Forum 16 05-15-2012 08:38 AM
Cruise Control Problems, GL1500 Steve G Goldwing Technical Forum 5 07-06-2011 07:46 AM
cruise control problems for gl1500 TUGWILSON Goldwing Technical Forum 28 06-12-2011 08:43 AM
Cruise control and cassette problems, GL1500 Jusu Goldwing Technical Forum 2 06-05-2008 06:52 AM
