post #1 of 13 (permalink) Old 02-19-2010, 01:38 AM Thread Starter
Trigger97's Avatar
My radio volume on my 97 1500SE is only at the mute volume even when the volume knob is at max and the mute button is not in. The "mute" indicator works on the LCD screen beside the speedometer. I've disassembled the mute button and it works fine. It is a simple 2 pole switch. I checked the connections and even put another radio in its place and still have the same problem. I made sure the CB was off when troubleshooting. All the knobs and buttons work fine, just very little volume. Also when I do turn the CB on, it will reach full volume. It appears after trying 2 radios with same results, that the problem is outside of the radio but not the mute switch. Any ideas?
Trigger97 is offline
post #2 of 13 (permalink) Old 02-19-2010, 04:18 AM
kb0ou's Avatar
Enjoy the peace and quite.
John C
My Rides; 1979 Goldwing, 1996 Dodge Cummins 400K miles Plus, 2005 Toyota Prius.
Previous Rides, lots of Hondas, 1972 BMW R75/5, SSBN Submarine.
Iron Butt Association #27222
HAM RADIO KB0OU
kb0ou is offline
post #3 of 13 (permalink) Old 02-19-2010, 05:13 AM
Yeah, I'm still here
Rudy's Avatar
Model: AmericanSportworks LMLSV
Send a message via Skype™ to Rudy
I'm thinking a shorted wire someplace between the two.
Rudy
"People give up their privacy for the chance at a $.10 off coupon!"
(quoted from conf. at ODNI)
Rudy is offline
post #4 of 13 (permalink) Old 02-19-2010, 09:44 AM
jimsjinx's Avatar
Model: 1999 1500SE Motortrike
Shorted headset wires in the helmet? jimsjinx
"We are put here, to take care of each other"
jimsjinx is offline
post #5 of 13 (permalink) Old 02-19-2010, 10:12 AM
Paid Site Sponsor
Model: 2015GL,2008GL,2000 Valk
5 amp fuse in relay box to the rear of the fuse box. I believe it is #13 and marked "Back Up". You probably jump started bike and blew this fuse, this is very common.
Wayne
Wayne is offline
post #6 of 13 (permalink) Old 02-19-2010, 10:57 AM
SteveBristol's Avatar
I had same problem when i boughtmy 91 15006 months ago
found it was the fader on dash. tried to take apart, it just fell apart in my hands
water had got in and rotted the "pot".
as the rear speakers were not functioning at all i just hard wired to front speakers for time being. weather warming i will sort properly..
.........................steve, hope this helps.
SteveBristol is offline
post #7 of 13 (permalink) Old 02-20-2010, 04:48 PM
elvisskan's Avatar
does the speedo work my radio is at low sound also and I was told it is in the connection near front wheel for the auto volume adjustment. I haven't fixed it yet but I have the directions on how to from someone on this site. I have it saved on my desk top if I can figure out how to post it I will or maybe someone will chime in. Hold on I think it is in my mail box here . 1. Jack the front wheel off the ground. 2. Remove the left rotor cover. 3. Remove the (one) screwthat holds the speedometer cable to the speedometer drive unit at the front wheel. 4. Roll the wheel forward and check if the "blade type" pin in the speedometer drive unit rotates. 5. If it rotates, then pull the inner speedometer cable out of the housing. 6. If the cable is broken, replace the complete speedometer cable (inner cable and housing) Part # 44830-MN5-000 7. If the "blade type" pin in the speedometer drive unitdoes not rotate,the teeth on the plastic gear in the unit is probably stripped. Part # 44806-MT2-003 However, don't purchase any parts until you diagnose the problem.
Past bikes:
1980 kawasaki 750ltd gone
1986 aspencade sold with 65,000 mile
many motocross bikes
If nothing changes than nothing changes
easy does it
thanks Bill W for my life today I wouldn\'t trade it for anything
elvisskan is offline
post #8 of 13 (permalink) Old 02-21-2010, 05:05 PM Thread Starter
Trigger97's Avatar
Thanks guys for your advice. I'll consider these options and let you know if one of them works. If not, I WILL enjoy the peace and quiet. God bless!
post #9 of 13 (permalink) Old 02-22-2010, 09:43 AM
Model: GL1500 ASP Lehman Trike
I have a J&M CB ON MINE AND IT WAS A BOX UNDER LEFT POCKET STUCK TO INSIDE OF FAIRING. i UNPLUGGED IT FROM FRONT OF RADIO AND SOUND WAS NORMAL AGAIN. This plug was a 12 wire connector and is used to mute radio when CB is broadcasting.
Radio will work without it being plugged in at all.
J&M replaced mine, their a great service place.
Good luck
The Trikester
Trikester is offline
post #10 of 13 (permalink) Old 02-22-2010, 11:24 AM
AQUAMAN's Avatar
Send a message via AIM to AQUAMAN
My 90 does the same thing but I found that by wiggling the wires that go to the radio I can get it working (until I hit another bump) drives me crazy, but until Rudy comes out and fixes this is what I got.
CUT IT TWICE AND ITS STILL TO SHORT!!!
Previous rides:Royal Enfield 250, Hodoka 90, Yamaha 80,160,QT50, Norton 250, BSA 500, Kawasaki 450ltd, Susuki 125, Vespa, Hondas CT90/110, C70, Twinstar, cb400F, 3-CM400A\'s, CM400C, CB650C, 7-CB900c\'s. Not counting all the off brand and home built mini bikes and mopeds.
AQUAMAN is offline
GL1500 Radio Volume Lost Luxo2r Goldwing Technical Forum 18 09-11-2013 11:28 PM
GL1800 intercom volume and radio volume is so low JUNIOR10 Goldwing Technical Forum 11 11-27-2012 08:43 PM
Radio Volume GL1500 aperry Goldwing Technical Forum 7 07-23-2012 11:15 AM
Speedometer and radio volume problem GL1800 buddy0230 Goldwing Technical Forum 10 03-04-2009 11:29 AM
radio volume dirt Goldwing Technical Forum 7 04-22-2006 04:50 PM
