post #1 of 12 (permalink) Old 03-08-2010, 11:16 PM Thread Starter
redz90's Avatar
Model: GL 1500 Aspencade
Send a message via AIM to redz90
going to do my first oil & filter change since buying this bike . I just need to know how much oil it holds when changing oil and filter.
It is a 87 GL 1200 aspencade
thanks
Be nice to all and hopefully all will be nice to you!!
Aspencade GL 1500
Aspencade GL 1200
Previous Bike Kawasaki Vulcan Classic,
Kawasaki Vulcan 1500
Suzuki 550
redz90 is offline
post #2 of 12 (permalink) Old 03-09-2010, 12:30 AM
hatchetman's Avatar
Location: Bowser, Vancouver Island, British Columbia, Canada
Should be around 3 & 3/4 liter or quart bottles. as you get to around 3 & 1/2, start looking in the sight glass as you add oil. Bike must be level for this. Than run the bike to make sure the filter is filled & let it sit for 5 minutes. Than check it again.
hatchetman is offline
post #3 of 12 (permalink) Old 03-09-2010, 08:08 AM
nsjoe's Avatar
Owners manual says 3.4 quarts...
Joe
Darksider #493
Former bikes:
\'80 CB750 Custom
\'86 GL1200 Interstate
nsjoe is offline
post #4 of 12 (permalink) Old 03-09-2010, 08:09 AM
nsjoe's Avatar
....with filter change... No sight glass on the 1200...check the dipstick.
Joe
Darksider #493
Former bikes:
\'80 CB750 Custom
nsjoe is offline
post #5 of 12 (permalink) Old 03-09-2010, 08:51 AM
Shooter's Avatar
Model: 2006 ST 1300
If you can't find the "SIGHT- GLASS", just send Hatchetman a p.m. I'm sure he'll be more than happy to install one for you...
1986 Interstate, 2006 ST 1300
Shooter is offline
post #6 of 12 (permalink) Old 03-09-2010, 08:53 AM
Also, your new oil fliter should come with new o-rings, one large for the cover, one small for the bolt. Use them. Be sure to lightly lube them first. Use hatchetmans proceedure, add about 3 1/2 quarts, run for about a minute after your oil light goes out. Check for leaks at drain and filter. Wait five more minutes with engine off. Check oil level and top off as needed to get to full mark. Please, please invest a manual and follow the maintenance proceedures. It will pay for itself over and over.
kapnkrunch is offline
post #7 of 12 (permalink) Old 03-09-2010, 08:59 AM
Had an 1100 that I installed a dipstick kit from JC Whitney, I think. It replaced the drain plug and made checking the oil a snap as opposed to lying on the ground to use the sight glass. Always figured it was an item that Honda should have installed at the factory.
post #8 of 12 (permalink) Old 03-09-2010, 01:45 PM
ARKnapp's Avatar
Model: None
I guess that when Honda built the 1100 series of bikes the end inspector for QC was a guy 18" tall and they made the sight glass for him to inspect the oil.
or
If you are prone to this you can use the inspection of your oil to start your exercise program.
or
before picking up dog doo doo, you can limber up with a stretch a long side of your bike
and it
allows you to inspect the under side and see the bottom of your tires.
It really is a PIA especially if your over 50 and you have joints that are 90, but it is a time nonoured custom and ritual that I do to honour the gods of Oil and Honda.
Praise to long life and the pursuit of riding!!!
ARKnapp is offline
post #9 of 12 (permalink) Old 03-09-2010, 02:35 PM
I second that one, PIA. Not to mention old eyes need a flashlight to see the oil behind the glass even on a sunny day.
post #10 of 12 (permalink) Old 03-09-2010, 07:14 PM Thread Starter
redz90's Avatar
Thanks Guys
Aspencade GL 1500
Aspencade GL 1200
Suzuki 550
redz90 is offline
Easy way to change rear 1500 tire not so easy. Chromo Goldwing Technical Forum 24 09-30-2011 06:59 PM
Easy tire change morriscatt Goldwing Technical Forum 21 03-28-2010 01:06 PM
Quick oil change question PapawRAS Goldwing Technical Forum 5 08-18-2009 08:58 PM
First Oil Change Question PA Chuck Goldwing Technical Forum 4 04-11-2009 10:41 AM
Oil Change question 1977 GL1000 bigcowhead Goldwing Technical Forum 9 09-28-2006 07:38 PM
