post #1 of 4 (permalink) Old 03-29-2010, 09:53 PM Thread Starter
I need the right equipment that will get the job done. Any suggestions on what kind and where to get it most appreciated.
escogold is offline
post #2 of 4 (permalink) Old 03-29-2010, 11:18 PM
A meter with a tach can be gotten at Harbor Freight. That, and ascrew driver, will get the job done.
post #3 of 4 (permalink) Old 03-30-2010, 09:53 AM Thread Starter
I've got an old tach/dwell/volt meter that I used to use for tune ups but it's not in increments of 50 so I'll check out the local Harbor Freight. Thanks Dennis.
escogold is offline
post #4 of 4 (permalink) Old 03-30-2010, 03:24 PM Thread Starter
I went down to Harbor Freight. I found two items that I thought might be what I need. One was a Cen-Tech Multimeter #95670 and the other was a Digital Contact Tachometer #66400. They had an optical Cen-Tech Tach too. I asked the guy that worked there but he didn't seem to know. The Multimeter was on sale for only $29.00. The Multimeter stated it would measure as a tach on the box. I'll do some research to try to figure out what will work but I could use some input.
escogold is offline
GL1200 IDLE DROP LOWERS MY HOPES. Bike...and Dennis Goldwing Technical Forum 135 05-04-2011 06:51 AM
can some one explain the idle drop procedure muaymendez1 Goldwing Technical Forum 5 07-15-2009 10:03 PM
Idle Drop??? Calflash Goldwing Technical Forum 6 08-06-2008 10:39 PM
Idle Drop Procedure 82 Red Wing Goldwing Technical Forum 1 08-03-2006 08:04 PM
Idle drop test b.pete Goldwing Technical Forum 6 11-05-2005 12:03 PM
