post #1 of 4 (permalink) Old 03-30-2010, 09:27 AM Thread Starter
I recently purchased an 86 Aspy with 86k and I am doing a tuneup. Whether they are truly needed or not I want to replace the plug wires. Does anyone have a good site that I can get the wires and caps from?
jbird526 is offline
post #2 of 4 (permalink) Old 03-30-2010, 11:11 AM
ARKnapp's Avatar
Model: None
Any auto supply or electrical wholesaler that handles gas fired appliances especially furnace repair, keep the same size wire. Clean all your parts including the coils, terminations and keep the length of HT leads about 1/2 longer so you can trim the end(s) periodically. Mark your wires as to 1, 2, 3, 4 near the plug connector.
ARKnapp is offline
post #3 of 4 (permalink) Old 03-30-2010, 02:04 PM Thread Starter
I ended up finding what I needed at Dennis Kirk at a good price.
Part# 2021
Spark Plug Wire Color: Black
Length: 72 in.
Type: Plug Wire - Universal
Units: Each
9.50 Lbs. $2.95 $5.90 4
Part# 20306
XD05F Spark Plug Cap Type: Plug Cap
Units: Each
0.48 Lbs. $3.55 $14.20
jbird526 is offline
post #4 of 4 (permalink) Old 03-30-2010, 03:19 PM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
i just bought a set of wires from summit and did away with the resistor caps,etc $41.95 + s/h part # G830
the wires are spiral wound for emi suppression and are low resistance which will provide a higher voltage to plugs
have not noticed any problems with radio reception
neoracer is offline
How to replace GL1200 Spark Plug wires. maoman Goldwing Technical Forum 14 08-19-2013 06:14 PM
1984 gl1200 plug wires WINGING Goldwing Technical Forum 4 08-07-2012 01:35 PM
GL1200 plug wires patmic02 Goldwing Technical Forum 3 04-29-2012 06:52 PM
GL1200 spark plug wires nwtroutguy Goldwing Technical Forum 3 12-23-2010 06:55 PM
GL1200 Spark Plug Wires copman70 Goldwing Technical Forum 6 05-19-2010 03:53 PM
