post #1 of 11 (permalink) Old 05-09-2010, 07:56 PM Thread Starter
indykev's Avatar
Hello,
I am new to this forum. I found it trying to find some answers to my carb issue. I recently purchased a 1987 GL1200 Aspencade that had not run for years. I have been stripping the bike down and replacing what needs to be replaced (and cleaning out the birds and mice nests). I pulled my carbs to clean them out and replace vacuum and fuel lines. Got everything cleaned up and replaced the lines and plugged the carbs back in. No problems. The bike fired up quick and the engine seemed to run good, considering it had sat for so many years. I started smelling gas and noticed it was leaking out of the upper "T" fitting on the middle of the carbs. It was leaking pretty bad, not just a drip. I have nothing connected to these fittings. I can't find what they connect to. I have searched other forums and tech sites and the only thing i've found is that nothing connects to these tubes, that they are vent tubes. If so, why do I have gas dumping out of them? Any help would be greatly appreciated
Just to clarify, the "T" fittings that I am talking about are in the middle of both carbs on each side and on the top. It looks like they would accept 5/16" inch or so fuel/vacuum line. I do have the bottom "T" fitting connected to a line. Also, I've scoured the Haynes manual and all of the parts diagrams I can find and find anything to help.
Sorry for the long post.
Thanks,
Kevin
indykev is offline
post #2 of 11 (permalink) Old 05-09-2010, 08:47 PM
SuperSkypilot's Avatar
Welcome to the forum. What your looking at is the vent lines for the float bowls. They had rubber hoses running down behind the engine. If your getting fuel out of them you have your float height set wrong. It's to high, that is it's less than .30" or you have a stuck float valve. What's happening is the float bowl is overflowing and the gas is running out the vent. You said "the bike fired up quick". Did you need to use the choke? I would guess that if you pull the plugs they will be carboned up because your running rich.
Steve
SuperSkypilot is offline
post #3 of 11 (permalink) Old 05-09-2010, 10:49 PM Thread Starter
indykev's Avatar
Hi Steve,
Thanks, Do you know of a good tutorial on here for checking and adjusting the float bowls?
Thanks,
Kevin
indykev is offline
post #4 of 11 (permalink) Old 05-09-2010, 11:45 PM
Randy Peterson's Avatar
Before you go to all the trouble of pulling the carbs off the bike and taking them apart you might try this. I had a 1200 with the same problem. I turned off the gas at the petcock and ran the engine until it died from fuel starvation. This allowed the stuck float valve to open all the way and dropped the floats for their full length of travel. When I turned the petcock back on I was lucky enough that the valve seated itself properly and the fuel leak stopped. It is definitely worth a try before you pull the carbs. Good luck- let us know what you find.
Randy Peterson is offline
post #5 of 11 (permalink) Old 05-10-2010, 12:07 AM
William_86's Avatar
Model: GL1500 Aspencade
mine had nothing connected to them, they are just vents for the float bowls, as the other guys said, your float valves might be stuck or the level is set extremely high
William_86 is online now
post #6 of 11 (permalink) Old 05-10-2010, 05:44 AM
I would highly recommend that you invest in a factory service manual. You can find them on Ebay. There used to be copies on line but I think Honda shut that down.
Steve
post #7 of 11 (permalink) Old 05-10-2010, 06:50 AM Thread Starter
indykev's Avatar
Thank you all very much. I have already pulled the carbs again and will check out the floats. BTW I purchased a fuel tank off of ebay. It was listed as the correct tank for my bike, but it turn out to be the fuel injected model. I am using the tank because it is in great condition. My old tank was NASTY. I have redone the plumbing where the fuel comes out of the bottom of the tank. Do I just cap off the fuel return? I am thinking this will take care of it.
Thanks again,
Kevin
indykev is offline
post #8 of 11 (permalink) Old 05-10-2010, 08:46 AM
Welcome to the forum, Kevin.
post #9 of 11 (permalink) Old 05-10-2010, 06:01 PM Thread Starter
indykev's Avatar
Thanks all for the replies and the welcome. My float were stuck, which makes sense on a bike that sat idle for 6 years with funky gas in it. I am going to check into that rebuild kit by Randakks. Anyone have any experience with it? From what i've read it is a popular kit with wingers.
indykev is offline
post #10 of 11 (permalink) Old 05-10-2010, 06:43 PM
William_86's Avatar
i rebuilt my carbs with randakks kit, best money spent on my bike ever. send me your email and ill sent ya the carb chapters from the three manuals i have, all of them helped me a lot to get them done with no background experience.
1984 GL1200 Choke / Carb Problem David in the Woods Goldwing Technical Forum 11 08-27-2011 06:28 PM
1984 GL1200 carb problem thomasthomas Goldwing Technical Forum 10 04-14-2011 08:42 PM
GL1200 Carb problem Biker_Billy Goldwing Technical Forum 2 07-09-2010 01:42 PM
gl1200 carb problem? Dancinbear Goldwing Technical Forum 3 08-14-2008 11:42 PM
GL1200 Carb problem tripps Goldwing Technical Forum 9 10-31-2006 06:23 AM
