post #1 of 7 (permalink) Old 05-19-2010, 05:48 PM Thread Starter
Model: 2012 GL1800 Airbag
Send a message via AIM to Firemedic268
I get a shake in the front in if I start to slow down without both hands on the handle bars. It is not bad but i can make it do this when I slow to a slow speed and jiggle the front end a little and then it straightens out. I haven't tried speeding up after it starts so I don't know if it gets worse with speed after it starts or if it gets better. I have loooked at the tires and can't see any cupping. The wheel bearing don't seem to have any play in them.
May you be a long time in heaven before the devil know you\'re gone.
Firemedic268 is offline
post #2 of 7 (permalink) Old 05-19-2010, 06:43 PM
johnmac's Avatar
Many wing have a shimmy at about 35 mph. Even a couple of fingers an a handlebar keeps it under control. If its worse than this, you may have a problem that needs addressed.
1996 GL1500 SE
Past bikes
1985 Aspencade 1200
1978 Honda GL 1000
1974 Honda 350 Four
1974 Yamaha TY 250 Trials
1973 Yamaha 360 RT3
1971 Honda SL 100
1968 Honda Trail 50
3 1/2 HP mini bike
johnmac is offline
post #3 of 7 (permalink) Old 05-19-2010, 06:53 PM
Who the heck cares?
rayworx's Avatar
Model: 88 GL1500
Double check the tire pressure... the #1 reason for almost any handling problem.
Steering head bearings could be worn or out of adjustment. Prop up the front wheel so you can rotate the handlebars from lock to lock. Put the bars in the center and very gently rotate back and forth only about 10degrees. If you feel a 'detent' right at the straight ahead position.... the steering bearings are worn.
There can be other causes but these are 2 of the most common.
If you don't have a service manual, nows the time to buy one!! It'll pay for itself real quick.
Ray
88 GL1500
rayworx is offline
post #4 of 7 (permalink) Old 05-19-2010, 07:03 PM Thread Starter
Tire pressure is good. Running32 in the front per manual and 36 to 40 in the rear per manual. will check bearings
post #5 of 7 (permalink) Old 05-19-2010, 08:42 PM
Odds are great that the headshake which common on almost all Goldwings is due to the front tire. I'm going to bet you have over 5000 miles on the front. Usually a new front tire will eliminate the hands free 35mph decelerating wobble. As the tire is worn the headshake slowly comes back. By the time you can see any cupping on the tire the wobble is usually back. It's not dangerous because normally just one hand lightly on a grip will prevent or stop it. The good news is that I've never heard of a 'Wing developing a high speed wobble which are dangerous.
post #6 of 7 (permalink) Old 05-20-2010, 10:38 AM Thread Starter
I honestly can't tell you how many miles are on these tires. I bought the bike in July of 2009. I have been trying to get everything up to par. I have been having fire/fuel issues. I am going to try to replace the fuel filter today. I just can't get rid of the problem of what sounds like a miss. I also have a colder muffler on #1 cylinder but runs good. Had it up to 101 this morning.
post #7 of 7 (permalink) Old 05-20-2010, 10:54 AM
copper204's Avatar
Model: GL1200A
Send a message via Yahoo to copper204
Sorry but seeing a hose dragger having FIRE issues out of his bike is funny.. Sorry BAD COP no donut for me.. back to my corner...
Be like me: LIVE YOUR LIFE IN SUCH A MANNER. THAT WHEN YOUR FEET HIT THE FLOOR. THE DEVIL SIGHS AND SAYS, "OH DANG HE\'S AWAKE"
and
copper204 is offline
Front end SHAKE, GL1500 tomk303 Goldwing Technical Forum 37 03-23-2014 03:39 PM
Front end shake GL1200 limo$mitch Goldwing Technical Forum 22 09-11-2011 06:57 PM
Shake in the front end, GL1200. Firemedic268 Goldwing Technical Forum 8 05-20-2010 08:45 PM
Front end shake. Wing-Rider Goldwing Technical Forum 5 12-09-2007 04:14 PM
Front End Shake BeeSharp Goldwing Technical Forum 11 04-08-2007 11:37 PM
