post #1 of 6 (permalink) Old 05-19-2010, 08:54 PM Thread Starter
Dr.Johnny's Avatar
I have a 81 GL1100 and I`ve been running 10W40, but I've noticed when the engine gets hot it sounds like a bag of marbles under the hood. If I went to a slightly heavier grade like a 15W40 would that help ? Also I have a gasket that needs replacing so I have a small oil leak, would there be a drop in oil pressure that may be causing this sound?
Face your fears and live your dreams. "Dreams never die just the dreamer".
Dr.Johnny is offline
post #2 of 6 (permalink) Old 05-19-2010, 09:49 PM
Big Cahuna's Avatar
When your oil is hot 10w40 and 15w40 wt oils are the same viscosity.You may want to try 20/50, the manual doesn't call for an oil that heavy, but lots of guys run it.I run Delvac 1300 15/40 diesel oil, and motor noise is next to nothing.,,
Bikes Ive owned, \'69 Norton,\'48 Harley panhead, \'71 Bsa, \'76 gl1000,\'93 Harley ultra,\'03 Harley ultra,\'05 Sportster, \'82 GW 1100.\'96 Police road king very used. "I tried thinking once, but nothing happened" .,,,
Big Cahuna is offline
post #3 of 6 (permalink) Old 05-19-2010, 10:05 PM
What, you didn't know about the marbles Honda put in the GW motors?
chris in va is offline
post #4 of 6 (permalink) Old 05-19-2010, 10:51 PM
I used to use DELO400 15W40 in my 1100s just like I do now in my 1500. It's a fact that 1100s do have a good bit of mechanical noise when running. If the valves are properly adjusted and the carbs well sync'd that goes a long way toward quieting them down but they are never going to be silently running mills.
post #5 of 6 (permalink) Old 05-19-2010, 11:43 PM
Lil Pete's Avatar
Big Cahuna wrote:
.....You may want to try 20/50, the manual doesn't call for an oil that heavy, but lots of guys run it.....
Actually, the Honda Shop Manual does specify conditions in which 20/50 is acceptable. Page 3-15 of the newest version covering '80 thru '83.
2008 GL1800B (Airbag)
Lil Pete is offline
post #6 of 6 (permalink) Old 05-24-2010, 11:27 AM
Jason's Avatar
Thin oil makes the 4 cylinder engines sound like rattlers, more so in summer. I find 20w50 is better for summer or all year round, and lighter oil for the winter months.
Jason
Jason is offline
60 weight oil blackknytecnc Miscellaneous Forum 4 08-05-2012 01:13 PM
what weight oil? freddyboy Goldwing Technical Forum 4 06-07-2010 05:35 PM
what weight Rottella Oil to use jshinklin General Motorcycle Discussion Forum 9 07-16-2009 12:23 AM
best weight for fork oil cj76 Goldwing Technical Forum 1 05-23-2009 12:01 AM
fork oil weight noobrider1 Goldwing Technical Forum 18 12-31-2008 09:12 AM
