post #1 of 13 (permalink) Old 05-20-2010, 08:50 PM Thread Starter
westgl's Avatar
I did a Carb Rebuild on my 86' GL1200, I used Randaaks Kit, & Howard Halasz book.
Boiled out my carbs. , set the floats, Sync'd carbs, and I have a flat spot/hesitation at the lower end of the RPM range.
I pulled the spark plugs, to see how the combustion burn looked. The plugs were all the same.
Insulator was white and clean, tip was white, looks like it is too lean.
How do I richen it up a bit. I thought is was the four screws that had the plugs over them.
Help!
Westgl
Current Bikes,
2005 Burgman 650 20K
westgl is offline
post #2 of 13 (permalink) Old 05-20-2010, 08:56 PM
Who the heck cares?
rayworx's Avatar
Model: 88 GL1500
As strange as it sounds... the spark plugs are supposed to look very white.
Also... if you took a short trip it isn't enough mileage to get any accurate color on the plugs.
If the hesitation occurs after the bike is fully warmed up (not just warm on the temp gauge but oil is warmed up to operating temperature) you might just need to adjust the slow speed screws. Screwing them out (counterclockwise) will richen the mixture. Try about 1/4 turn at a time.
Are you sure that all cylinders are firing evenly?
Ray
88 GL1500
rayworx is offline
post #3 of 13 (permalink) Old 05-20-2010, 09:46 PM Thread Starter
westgl's Avatar
I warmed up bike to operating temp before leaving the driveway.
I Then rode about 10 Miles under a load, got up to 85 mph.
Before the rebuild I noticed a tan to a gray spark plug tip which should be very normal
Westgl
Current Bikes,
westgl is offline
post #4 of 13 (permalink) Old 05-20-2010, 10:32 PM Thread Starter
westgl's Avatar
I think Iam just about done.
I may go to a single or dual carbs.
I have had it, I have these $#@%*^ carbs out 6 times, looking for the problem.
I have gone through countless hours trying to get them to work.
I have had it with those so%- of a &*%@%$# carbs
OK I feel much better now.
I am switching to single or dual carbs.
westgl
Current Bikes,
westgl is offline
post #5 of 13 (permalink) Old 05-20-2010, 10:45 PM
William_86's Avatar
Model: GL1500 Aspencade
try playing with the choke(enricher) if it helps then its running lean.
William_86 is offline
post #6 of 13 (permalink) Old 05-21-2010, 08:42 AM Thread Starter
westgl's Avatar
Hi William86,
I have tried using the choke enrichiner, thats another reason why I think it is lean. I put the choke on and it runs much better.
But how do I make it richer.
Thanks Guillermo
westgl
Current Bikes,
westgl is offline
post #7 of 13 (permalink) Old 05-21-2010, 10:03 AM
jwhitmore44's Avatar
It depends on where you need the richness at. If you need it richer at idle then the air mixture screw will help (actually it will help at above idle too). If you need richer running at half to to full open throttle then you have to change the main jet. Changing the idle jet will also help from idle to half throttle (or 1/4 throttle).
I think part of the reason of the complaints about these bikes being cold blooded is that the idle jet is a bit lean to begin with. They run fine when warm so most folks just wait for them to warm up.
03 Honda XR650L
84 GL1200 Aspencade
jwhitmore44 is offline
post #8 of 13 (permalink) Old 05-21-2010, 10:41 AM
Lightin's Avatar
About 30 miles and check plugs
John3:16
1st bike 125HD in 1969
250Honda Dream
750Honda
10 HD
89aspencade
1994 GL 1500 Trike
Past
91HD Maybe Trike project
Lightin is offline
post #9 of 13 (permalink) Old 05-21-2010, 11:52 AM
William_86's Avatar
if you blowed compressed air through all tiny holes then you can be 99% sure carbs are clean.
how many turns out you turned the pilot screws? (those with the plug) the manual recalls to use 2 turns out for the 86 model
post #10 of 13 (permalink) Old 05-21-2010, 05:30 PM Thread Starter
westgl's Avatar
I set carb. pilot screws at was about two turns.
Any more open and the bike starts running rough, and does not want to rev very well.
But set at two turns it will rev but has a flat spot &hesitation just off idle.
and again the plug tip is white, insulator is white and clean.
Low speed jet appeared to be plugged.
Does anyone know what size drill bit the #40 low speed jet is? I want to verify that, that jet is not partially closed.
Thanks
westgl
poyb likes this.
Current Bikes,
westgl is offline
1990 GL1500SE Carb Rebuild Kit Question RabbiRider Goldwing Technical Forum 2 12-16-2011 10:03 AM
GL1200 carb rebuild question Wing Bucket Goldwing Technical Forum 3 08-10-2010 05:57 PM
78 gl1000 carb rebuild question morriscatt Goldwing Technical Forum 9 10-10-2008 08:22 PM
GL1100 carb rebuild kit question thefid Goldwing Technical Forum 4 05-17-2006 09:00 AM
Another newbe carb. rebuild question Lew Goldwing Technical Forum 6 12-03-2005 11:59 AM
