Old 06-25-2010, 11:21 PM   #1 (permalink)
Hey Guys,
First time post-er here and was looking on the forum for my problem but couldn't find it. Closest was this one.
http://www.goldwingfacts.com/forums/...rting+troubles
I have been having trouble with the engine turning over. Just sounds like the battery is dead. The engine might turn over a couple times super slowly and then the relay starts to click on and off.
I have tried a new battery, boosting from a car battery, re-did all the starter wiring, cleaned posts. When that didn't work I though "must be the starter". Put a brand new one on today and it has the exact same problem. I tried boosting right to the started post and there is still an issue. At times it will fire just enough to start and when it is running it runs awesome. It had a total engine rebuild a year and a half ago.
The only other thing is that when it is being boosted the posts will smoke and the booster cables get pretty hot.
I am completely stumped
kieran is offline   Reply With Quote
Old 06-25-2010, 11:37 PM   #2 (permalink)
Super Moderator
AZgl1500's Avatar
Goldwing Model: GL1800 Hot Rod Yellow in '02
bump for you
__________________
hint, ya hafta click on the link to see it
Forum Index
Get your own Bookmarks.
easy peasy
http://tiny.cc/kd69bx___
AZgl1500 is offline   Reply With Quote
Old 06-25-2010, 11:45 PM   #3 (permalink)
brianinmaine's Avatar
Goldwing Model: 1980 GL1100
I like to break everything down into components.
1. motor - does it turn ever easily by hand?
2. battery - you said it was new?
3. start solenoid - maybe bad inside, you can rebuild or replace
4. starter - new also?
5. wires/cables to and from the start solenoid to both battery and starter.
That's all the pieces to the starting circuit. So it looks like maybe the start solenoid is the best bet?
Another thought, what weight oil?
__________________
Brian Trauger
1980 Standard : Pacifico fairing : Honda trunk.
brianinmaine is offline   Reply With Quote
Old 06-25-2010, 11:53 PM   #4 (permalink)
Goldwing Model: 1987 GL1200 Interstate 275,000 miles
Welcome to the forum, Kieran.
Hot cables and smoking posts. Doesn't that mean too much resistance? It seems unlikely that a new starter wouldhavethe same defect as an old one, but not impossible.
I didn't see a replacement solenoid mentioned, but, if you jumped from the battery to the starter and got the same results...
My best guess would bea problem withthe starter's ground.
__________________
Bike...and Dennis is offline   Reply With Quote
Old 06-26-2010, 12:07 AM   #5 (permalink)
Thanks for the quick reply guys.
The solenoid? is this the same as the ignition relay?
there is no issue with the battery as I have tried boosting with many different batteries.
I will pull the plugs and try to to turn the engine by hand and see what happens.
the starter was bought new and since it is doing the same thing with the new one I either have two bad starters or two good ones meaning the problem is something else.
I thought the same thing myself withe ground but re wired that as well and it is all good.
As for the oil, also not sure on the weight. Will ask my pops and see but I am 99 percent sure that it is normal.
Old 06-26-2010, 12:16 AM   #6 (permalink)
morriscatt's Avatar
To clarify, did you clean/re-do the bike ground behind the triangle?
__________________
Patrick Morrissey (Go Irish)
Started on family owned Cushman Scooter
First Bike was a 1967 Riverside 125cc
Dad\'s 78 GW ashes.
Bringing another 1100 back to life, rising from the ashes of my 1000... Thanks to this forum!
"Enjoy the Ride"
morriscatt is offline   Reply With Quote
Old 06-26-2010, 12:21 AM   #7 (permalink)
Okay, morriscatt - yup that is the ground I cleaned. Checked it with and ohm meter as well and it all looked good.
I understand this was probably not the most orthodox way of check to see if the engine moves freely but I pulled the plugs and turned the engine over in neutral to see if the compression was the main resistance for the starter. The starter spun really well. Then I thought, why not through it in gear to see what happens when I turn it over with I bit more resistance to the starter motor. Again the starter motor preformed well and spun fast turning the rear wheel while on the center stand.
What does everyone think?
Old 06-26-2010, 12:22 AM   #8 (permalink)
I am in the same boat...but i just finished retiming the bike.
I found my right cam was off...tommorrow i will see if she cranks
mieze245 is offline   Reply With Quote
Old 06-26-2010, 12:26 AM   #9 (permalink)
ya mieze, I can't see that being my problem as it runs fine, starts fine, and even took it for a spin today by pushing it down a hill to start it. Just using the starter the issue.
Old 06-26-2010, 12:37 AM   #10 (permalink)
Keno's Avatar
Disconnect starter cable at solnoid and jump straight to starter. will eliminate every thing but the starter. Post on starter may be shorted if it has ever turned even on new assembly. Keno
Keno is offline   Reply With Quote
2001 Honda GoldWing cranks good but no start ebonyquincy Goldwing Technical Forum 15 05-26-2012 01:46 PM
GL1000 slow to no hot start fix? newbuckwing Goldwing Technical Forum 8 05-05-2012 12:51 AM
Cranks longer to start when cold Tex Goldwing Technical Forum 3 03-05-2010 06:31 PM
78 GL1000 won't start wanger55 Goldwing Technical Forum 7 07-18-2008 07:11 PM
1980 GL1100 Cranks, Backfires Does not Start Nightrider1 Goldwing Technical Forum 8 06-03-2008 03:38 AM
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.6.0 PL2
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Shoutbox provided by vBShout v6.2.1 (Lite) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
Motorcycle News, Videos and Reviews
Honda Grom Forum Harley Davidson Forum Honda 600RR Forum Kawasaki Forum Yamaha R6 Forum Yamaha FZ-09 Forum
1199 Panigale Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
Ducati Monster Forum Harley Forums Honda CBR250R Forum ZX10R Forum Star Raider Forum Yamaha Viking Forum
Suzuki GSXR Forum V-Rod Forums Honda Shadow Forum Kawasaki Motorcycle Forum Star Warrior Forum KTM Duke 390 Forum
SV650 Forum BMW S1000RR Forum Honda Fury Forum Kawasaki Versys Forum Drag Racing Forum Ducati 899 Panigale Forum
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes BMW NineT Forum
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum Suzuki GW250 Forum
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
