post #1 of 25 (permalink) Old 06-30-2010, 08:14 PM Thread Starter
Can anyone tell me if there is an off the shelf substitute oil filter for a GL1800 andhow many miles should I put on the bike before I change to Mobil 1.My understanding is I can use automotive Moble 1 since this is a water cooled engine instead of using the V-Twin Mobil 1 due to less het being produced.
nvrpc is offline
post #2 of 25 (permalink) Old 06-30-2010, 08:46 PM
Year: 2008
Make: Goldwing
I use Amsoil 10/30 motorcycle oil and the short walmart filter and change every 8000 miles (once a year) I did change at 1k, 4k and 8k. This works for me, others will disagree. I would also be comfortable with dino mc oil and change every 4k. Stay away from energy conserving oil as it might make your clutch slip. Don
don55 is offline
post #3 of 25 (permalink) Old 06-30-2010, 08:54 PM Thread Starter
What would be the PN for the Walmart, Fram, Puerlator, Etc Oil filter for a GL1800
nvrpc is offline
post #4 of 25 (permalink) Old 06-30-2010, 09:03 PM
Oil is oil is oil is oil and will start a war.
But I say stay with the Honda filter. Forget the stuff about how better on is over the other as far as being a filter.
The honda one has a good strong outer shell. Important to ward off rocks and gravel and other such things.
Those others the outer metal can is pretty flimsy.
Besides you can buy the Honda one in bulk for about 5 or 6 dollars each.
Try Chromeworld.
Kit
Kit
Kit Carson is offline
post #5 of 25 (permalink) Old 06-30-2010, 09:25 PM
Year: 2008
Make: Goldwing
This will link you to some information. Don't agonize about price. If you feel comfortable about paying more or less for a filter go for it. The price difference is only a few bucks a year. From what I read, the walmart filter does an excellent job at a good price. I will cut one next spring and measure the thickness if anyone is interested. If anyone has measured a honda filter I would be interested in it's thickness. If they are thicker I would switch to the honda filter. Don
http://www.texasroadrangers.com/MAINTENANCE_TIPS.html
don55 is offline
post #6 of 25 (permalink) Old 06-30-2010, 09:32 PM
From the goldwing tips section;
[align=left]GL1800 Aftermarket Oil Filters. PurolatorML16817, Napagold1358, Carquest 85358, Wix51358, AC Delco,PF2135, Fram PH6017Aand K&NKN 204.[/align][align=left]I use Honda car filters, 15400-PLM-002 had to move the left horn a little to make room for a little more length but I get them free.
[/align]
[SIGPIC]
post #7 of 25 (permalink) Old 06-30-2010, 09:47 PM
Year: 2008
Make: Goldwing
A quick check shows the walmart filter is 10 mil thick and the oem filter is 20 mil thick. I will buy the honda filter next spring. Don
don55 is offline
post #8 of 25 (permalink) Old 07-07-2010, 02:17 PM Thread Starter
Well we have the oil and the oil filter but I was reading the owners manual and it says to torque the drain plug to 25 ft''lbs. Is that correct or should it be 25 in/lbs. I also am going to change the differential oil to get any metals particle that may have occured in the firt 500 miles with Amsoil Sever Gear 75-90 http://www.amsoil.com/storefront/svg.aspx Does anyone see a problem with that or had expereince with this oil. I use it on my truck and the test results are great. The test can be found here and I was impressed http://www.amsoil.com/lit/g2457.pdf
nvrpc is offline
post #9 of 25 (permalink) Old 05-02-2011, 04:45 PM
dbtroudy's Avatar
Year: 2003
Send a message via Skype™ to dbtroudy
Has anyone tried the Walmart ST 6607 (2") or the Walmart ST 7317 (3 In) size filter for the GL1800? The referenced Texas Road Ranger website lists the ST 6607 as the "The Best". These filters are certainly cheap at $2.84 each here in So Cal. Just curious to see what anyone's experience has been with them.
Don
Diamond Bar, CA
DBTroudy
Diamond Bar, CA
1976 GL1000 Yellow
1976 GL1000 LTD #859
2003 GL1800 Yellow
1975 GL1000 Blue Green
dbtroudy is offline
post #10 of 25 (permalink) Old 05-02-2011, 06:29 PM
Old School Guru
GLester's Avatar
Year: 2007
Make: Goldwing
dbtroudy wrote:
Has anyone tried the Walmart ST 6607 (2") or the Walmart ST 7317 (3 In) size filter for the GL1800? The referenced Texas Road Ranger website lists the ST 6607 as the "The Best". These fitlers are certainly cheap at $2.84 each here in So Cal. Just curious to see what anyone's experience has been with them.
Don
Diamond Bar, CA
I've used them both, the 6607 on they 1500, and the 7317 on the 1800. They are both good filters, and have never had a problem with either. I also use Mobil1 4T Racing Synthetic Oil in my 1800. Shifts nice and smooth, and when I change the oil, it is still pretty clean, at 5k.
Gene
Gene Lester
Arkansas Chapter
Darksider #265
GLester is offline
GL1200 SPIN ON OIL FILTER ADAPTOR + FILTER (Car) SIZE + OIL GRADE franky932 Goldwing Technical Forum 19 10-12-2012 08:34 PM
GL1800 oil filter roadwarrier Goldwing Technical Forum 2 06-19-2012 07:34 AM
Oil Filter for GL1800 bee8ch Goldwing Technical Forum 5 10-14-2011 08:05 AM
GL1800 Oil Filter tj5iveo Goldwing Technical Forum 2 04-10-2011 08:57 PM
GL1800 oil filter wing nut Goldwing Technical Forum 23 10-17-2009 09:12 PM
