post #1 of 25 (permalink) Old 07-12-2010, 05:39 PM Thread Starter
wallowaman's Avatar
I do have one question relating to exhaust: I would like to make the pipes a bit louder w/out having to spend a whole lot of $$. I know that one option is to remove the mufflers from the tubes and remove some of the packing and put it all back together.
My concerns are will this change the back pressure enough that i will have to make adjustments on the carburetors? How much can i safely remove? Any thoughts? Has anyone else on this forum done this? If so i would really appreciate hearing from you.
Thanks,
Roger
Roger
1984 GL1200 Aspencade
"People may drive you crazy, just don\'t let \'em drive you nuts!"
wallowaman is offline
post #2 of 25 (permalink) Old 07-12-2010, 06:14 PM
A lot of the folks here seem to think Harley muffles work. Don't damage the stock exhausts. A lot of peoplewant them.
post #3 of 25 (permalink) Old 07-12-2010, 06:26 PM
SuperSkypilot's Avatar
Like Dennis said the stock mufflers are worth some money. If your going to mess around you can pickup almost new HD mufflers for under $100. Then when you get tired of the racket you can put the stock ones back on.
Steve
SuperSkypilot is offline
post #4 of 25 (permalink) Old 07-12-2010, 06:28 PM Thread Starter
wallowaman's Avatar
So pardon my ignorance but do these fit directly into the stock pipes? Or? Where can i get them?
Roger
post #5 of 25 (permalink) Old 07-12-2010, 06:33 PM
William_86's Avatar
Model: GL1500 Aspencade
the stock exhaust without baffles will be louder, but in my personal opinion, the sound sucks. so probably the harley mufflers is your choice.
they fit directly but since they are cheap everyone uses them. they are louder than stock but not enough to screw your ride.
William_86 is online now
post #6 of 25 (permalink) Old 07-12-2010, 06:51 PM
The Harley mufflers may take some doing to install but they are cheap. Seeyour local Harley dealer. They should know who has just bought megaphones for their hog.
Aftermarket pipes are available for your bike that will change the sound and will bolt right on. They are not cheap.
post #7 of 25 (permalink) Old 07-12-2010, 08:53 PM
grambo's Avatar
older stock touring pipes are good replacement and dirt cheap and you can bang em thru too
the newer ones(smogged and baffled...epa) are totally junk and you cant bang em thru...no performance and sound like junk...thats why people take em off and put real pipes on their harley.
91 GL1500
91 Electraglide
Ask the wrench god 1st!!
grambo is offline
post #8 of 25 (permalink) Old 07-12-2010, 10:52 PM
brianinmaine's Avatar
Year: 1980, 1987
Make: Goldwing
Model: 1980 Standard, 1987 Aspencade
Maine is making them illegal, the "real" pipes I mean. I would imagine other places also. I'm not really an "outlaw biker", it kind of goes against the Goldwing thing, in my opinion. I like stock. I tried the Harley pipes, but as soon as I got some stock, I put them on.
Brian Trauger
1980 Standard : Pacifico fairing : Vetter trunk.
1987 Aspencade : Fully dressed.
brianinmaine is offline
post #9 of 25 (permalink) Old 07-13-2010, 01:08 PM
gaspredator's Avatar
You can consider taking out the expansion chamber, located just in front of both mufflers (they connect onto it). I took out mine, went to NAPA auto and got 1.5" od x 1.5" id 22.5 degree exhaust elbows and directed each header out through each stock muffler on each side. The sound got a bit louder, but not enough to rattle your brain like harley pipes will. I deffinately gained some HP and got about 2 mpg better mileage. I spent under $15 for the mod. I also talked to our local goldwing mechanic and he said it would NOT hurt anything.
can\'t stand a 4 wheel cage anymore !!
gaspredator is offline
post #10 of 25 (permalink) Old 07-15-2010, 10:59 AM Thread Starter
wallowaman's Avatar
OK fellas. I found a couple of different sets of Harley take off pipes. One set it about 22 1/2 inches in length, the other is 28 1/2 inches. So my question is do I install them directly off of the headers or do I have to modify the pipe behind the chamber to getthem to fit?
If i go straight off of the headers with the 28 1/2 inchers, they come out about 3 inches from the back of the tire. If I use the shorter ones, then, well they come out near the front of the back tire.
Any thoughts or advice would be greatly appreciated. Thank you again to all for your help and advice.
Cheers!
Roger
Roger
best modification i ever made Tinman General Motorcycle Discussion Forum 11 03-27-2011 04:04 PM
Stock exhaust extension modification, GL1800 chrisgl1800 Goldwing Technical Forum 2 02-26-2011 08:40 AM
exhaust modification? naked gl 1100 Goldwing Technical Forum 8 07-30-2010 08:35 PM
Saddlebag modification 1984GL1200TX Goldwing Technical Forum 7 12-11-2008 05:44 AM
Poorboy Modification BillM Goldwing Technical Forum 2 05-18-2006 06:40 PM
