post #1 of 5 (permalink) Old 08-26-2010, 11:40 PM Thread Starter
Busdriver
busdriver's Avatar
Year: 1990
Model: GL1500, 172,000 KM
Has anyone tried running with the spark plug cap resistors removed?
If so, what results did you find, good, bad or no change?
Did you have to replace the resistor with a piece of metal to be able to fit the cap to the spark plug?
For those who simply replace the resistors, where do you find them? I suppose they are NGK or similar, but don't know what ohm value.
busdriver is offline
post #2 of 5 (permalink) Old 08-27-2010, 01:01 AM
well on my 1000 ichanged out the resistors. they where bad for metal rod made a heck of a diffrence I an resistor plugs. I changed it out to new restor boots and non resistor plugs later on and ran the same as with resistors out. Not shue of 1500 but most bikes have 5000 ohm resistor's.
The problem is with the connections inside the boot over time that is why I went with new boots.
wilf
79 gl1000 dresser
80 gl1100I now naked
90 1500 full dress
wilf is offline
post #3 of 5 (permalink) Old 08-27-2010, 06:39 AM
jwhitmore44's Avatar
I've removed the resistors on one of my dirt bikes and an ATV. Replaced the resistor with a piece of stainless screw that I cut to the same length. It didn't seem to affect the dirt bike (XR400) but it stopped the hard starting and fouling of the plug on my ATV (KEF300). Not sure what the end result will be with my ignition system though Part of the resistor function is to make sure that the ignition system has enough load on it to perform correctly.
If I though I had problems with the ones on my wing I would replace the whole spark plug boot.
03 Honda XR650L
84 GL1200 Aspencade
jwhitmore44 is offline
post #4 of 5 (permalink) Old 08-27-2010, 07:00 AM
Xtracho's Avatar
Location: Panama City Beach, FL and Rio de Janeiro, Brazil
Model: '84 Aspencade
I removed the caps and replaced with Accel 7mm copper core plug wires and run NGK Iridium Plugs. No performance issues for me. But I'm not running a radio at this time so I have no idea what the effect of RFI would be.
Mark
1984 GL 1200 Aspencade
To live you must be willing to die - Amir Vahedi
My father gets smarter everyday that he's gone.
I worried that I had no shoes until I saw a man that had no feet.
Xtracho is offline
post #5 of 5 (permalink) Old 08-27-2010, 11:40 AM
Think we need to combine this thread with http://www.goldwingfacts.com/forums/forum1/99131.html
03 Honda XR650L
84 GL1200 Aspencade
GL1100 rusty spark plugs/spark plug wires? machineman2101 Goldwing Technical Forum 5 04-03-2012 06:01 PM
Spark plug cap GL1100 phideux Goldwing Technical Forum 5 04-06-2011 09:16 PM
GL1500 spark plug cap resistors stevielinker Goldwing Technical Forum 4 10-08-2009 09:50 PM
spark plug cap freonrick Goldwing Technical Forum 8 05-31-2009 09:17 PM
broken spark plug wire? broken spark plug boot? AmpGoes211 Goldwing Technical Forum 8 03-29-2008 07:36 AM
