post #1 of 8 (permalink) Old 09-03-2010, 07:39 AM Thread Starter
I Just bought a 2008 airbag model. The low beam lights are raised as far as the up button allows, but when riding in the dark, they don't reach out any further than a couple of lane divider stripes. How can I get them up some? I have the windscreen as low as it goes and when sitting in a normal position the light reachesout the same distance as the top of the screen. In other words,I cansee light thru the screen but only darkness if I look over the screen. Thanks in advance.
Dave R. is offline
post #2 of 8 (permalink) Old 09-03-2010, 11:23 AM
Senior Guru
GWNorman's Avatar
Model: GL1800, GL1500, GL1200
This should be in the Technical Forum, any moderators please move it over?
GWNorman is offline
post #3 of 8 (permalink) Old 09-03-2010, 12:55 PM
Tookie's Avatar
More air in the front tire?
Sorry, couldn't resist.
I can't help, but maybe the rear suspension is set too high?
Tookie - 2002 GL1800
2002, 10,000 miles on it when purchased in May '10.
20,000 miles as of December 2011
26,000 as of October 2013
Installed:
Every Baker wing made, belly pan, Butler mug, J&M Digital music player,
rear speakers, Kury handlebar risers and armrests, brake modulator....
Double Darksider, # 922 @17,700 miles...
Tookie is offline
post #4 of 8 (permalink) Old 09-03-2010, 01:17 PM Thread Starter
Could be I suppose but the preload is set at 4. Seems like that would be OK. I'm just wondering if these adjust like on a car by turning an adjustment screw. Maybe this is what I should expect. If it is then I can see why Honda made allowances for add on lights.
Dave R. is offline
post #5 of 8 (permalink) Old 09-03-2010, 03:41 PM
Tookie's Avatar
3 seconds on Google got this, not sure if it's up and down, or side to side
http://www.wingman26.com/headlight.html
Or here
or here
That ought to be enough for ya!
Installed:
Tookie is offline
post #6 of 8 (permalink) Old 09-03-2010, 03:54 PM Thread Starter
Or here
or here
Thanks Tookie;
Itried a Google search but must not have used the correct criteria. Appreciate the assist. Thanks
Dave R. is offline
post #7 of 8 (permalink) Old 09-03-2010, 07:56 PM
Tookie's Avatar
I am gonna do this to mine too, my headlight is at the top of the adjustment
right now
Installed:
Tookie is offline
post #8 of 8 (permalink) Old 09-03-2010, 08:20 PM
All of them seem to be set too low from the factory.turn both screws in the picture in the link about 4 full turns clockwise as you are looking at them from the bottom.
[SIGPIC]
GL1800 HEADLIGHT ADJUSTMENT HELP Wildman007 Goldwing Technical Forum 4 09-18-2011 04:42 AM
Headlight Adjustment goldwingcop Goldwing Technical Forum 7 02-14-2011 09:00 PM
84 GL1200 I - Headlight adjustment azdesertdad Goldwing Technical Forum 2 05-28-2010 12:53 AM
GL1800 Headlight Adjustment cubix Goldwing Technical Forum 7 09-02-2009 11:34 AM
Headlight adjustment kevlarkenner Goldwing Technical Forum 4 12-26-2008 03:57 PM
