post #1 of 12 (permalink) Old 09-23-2010, 12:58 PM Thread Starter
My hondaline CB , on my GL 1800 air bag , year 2006 ,can not RECEIVE any more . I installed it one year ago , and has not had any problems so far , but suddenly one day , travelling with a friend , i could`t hear him anymore . I can transmit and everyone can hear me clearly , in 2 miles distance or more . The problem is the same on headset or speakers . When i turn down the squelsh to 2, i will receive some " white noise " , ( and the RX sign will show up on the display , and the radio/cd will mute ) , but the "white noise" is not so loud ,as it was when it worked OK .
Do you think this problem is in the CB unit itself , or ??? ( Yes i have checked the settings , and i now what the different switches are for ).
Thank you for any help .
post #2 of 12 (permalink) Old 09-23-2010, 04:53 PM
jwhitmore44's Avatar
Since it can transmit I would say the antenna is still connected properly. Also i would say the mic is working. About the only thing that leaves is the radio itself.
03 Honda XR650L
84 GL1200 Aspencade
jwhitmore44 is offline
post #3 of 12 (permalink) Old 09-23-2010, 05:22 PM
corventure's Avatar
Have you checked a couple simple things first?
When you push the PTT switch, do you see TX on the dash? If so have you tried swapping out helmets and cords with another set or a buddies set? Do you have a passenger PTT switch?
corventure is offline
post #4 of 12 (permalink) Old 09-25-2010, 01:16 PM Thread Starter
Yes the TX is coming on , and as i told , everybody can hear me clearly . Yes i have tried another helmet( but i dont think it is an issue , when i can`t receive thru the speakers either ). No i dont have the passenger switch . ( nobody dares to ride with me , LOL ).
post #5 of 12 (permalink) Old 11-14-2010, 11:25 AM Thread Starter
I AM TRYING AGAIN !
I still have this problem ;-My CB can transmit but not receive !
Nobody else has had this problem ???
The unit is manufactured in august 2008 , and made by Radio Sound, Inc.
I have bougth it from a Honda dealer in USA , is the Warranty limited to one year ?
post #6 of 12 (permalink) Old 11-14-2010, 02:50 PM
Other side of the pond
englishted's Avatar
Sorry to bear bad news Smeden, but your CB unit is bad. Check for water damage, a lot of GL1800's leak water into the trunk and it pools under the CB radio.
Ted Kelly.
englishted is offline
post #7 of 12 (permalink) Old 11-14-2010, 09:19 PM
Friends playing a cruel joke on you?
chris in va is offline
post #8 of 12 (permalink) Old 11-15-2010, 02:02 AM Thread Starter
chris in va , -yes i nov this joke (some of us ,once acted as we could not hear a guy with a brand new self installation , and it was great fun for all , except one).
BUT i have checked that , and the problem is not located there .
englishted , -there is no sign off water , but i think i will borrow another unit ,and check with that .
BY THE WAY - some says that the Clarion unit is more reliable than the Radio Sound ,any comments ?
post #9 of 12 (permalink) Old 11-15-2010, 10:47 AM
corventure's Avatar
I think you are doing the right thing by borrowing another unit to test, however it is sounding more and more like the radio is a problem. I believe Sierra Electronics.. Sierra-mc.com can repair your CB radio if it is out of warrantee.
Unfortunatly ther are here in Nevada, USA.
post #10 of 12 (permalink) Old 11-19-2010, 08:22 PM
CHECK THE GROUND ON THE ANTENA
ace20021955 is offline
GL1800 CB Radio nvrpc Goldwing Technical Forum 14 11-30-2011 07:53 PM
not receiving PM's russell Test Forum 4 05-27-2011 11:16 AM
GL1800 AM in Radio SkipWiley Goldwing Technical Forum 9 11-29-2010 04:38 PM
CB Radio GL1800 wingpass General Motorcycle Discussion Forum 8 07-07-2009 10:36 PM
