2Likes
post #291 of 297 (permalink) Old 08-17-2015, 10:19 PM
willwilly's Avatar
Model: GL1100 Interstate (Now Naked)
Thanks Dave. I'll check that out. By the way, love your new mount design. Just reread the thread to catch up...
willwilly is offline
post #292 of 297 (permalink) Old 08-17-2015, 11:59 PM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
Here is what I did for what it is worth.
The 1500 coils are shorter but still use oem mounting.
cost me $40 and I got a spare coil to put on the shelf.
help on vacation with a failing coil
Convert 4cyl. Oldwing coils to newer GL1500 Coils for Hotter spark
JeffMayfield is offline
post #293 of 297 (permalink) Old 08-18-2015, 06:53 AM Thread Starter
junior moderator
Gee Jeff, there might just be another thread on that.
[SIGPIC]
post #294 of 297 (permalink) Old 10-25-2015, 09:10 PM
Model: GL1100
Dave, where do you wire in the ballast resistor on this setup. Between what and what?
tvtruth is offline
post #295 of 297 (permalink) Old 10-25-2015, 11:01 PM Thread Starter
junior moderator
I don't use a ballast on 1100s.
[SIGPIC]
post #296 of 297 (permalink) Old 04-07-2016, 10:59 PM
roadkill750's Avatar
Year: 1986
Model: GL1200
Read through all pages of this three times and have decided to go through with this...went out to my 86 Interstate today to check if it's a black sticker or green sticker....turns out it's neither! It's Blue has anybody else had a blue sticker...the bottom is plastic. I'm going to open it and see what the heat sink looks like
roadkill750 is offline
post #297 of 297 (permalink) Old 06-10-2016, 02:47 AM
jeffcosmo's Avatar
Model: 1983 Aspencade
Just did this mod. Couple things I found out:
a) The resistor limits power to the coils. The Neon does not use such a resistor, so it's 12v to the coils.
b) mounting on a fully loaded Aspy was accomplished with four pieces of strap about 30mm long with holes on 10mmm centres, bolted to the stock coil mounts, which bolt back just as Mother Honda would wish. The rear bolt through the top of the coils and the top of the mount, the front just opposite. Gives the perfect positioning, and requires no welding.
Cosmo
Posted with a Gennie Navaho blanket and traditional flames
jeffcosmo is offline
81 thru 83 gl1100s countryboy843 Goldwing Technical Forum 9 03-30-2011 05:58 AM
Do all Gl1100s sound... byrnesrick6886 Goldwing Technical Forum 42 08-23-2010 03:45 PM
Jardines and GL1100s sandcastcb750 Goldwing Technical Forum 5 04-09-2010 05:05 PM
GL1100 coil and GL1200 coil teacher Goldwing Technical Forum 11 12-23-2006 12:02 PM
Jetting GL1100s goldwingergl1100 General Motorcycle Discussion Forum 2 03-04-2006 11:20 PM
