post #1 of 8 (permalink) Old 10-31-2010, 06:27 PM Thread Starter
KC5TF's Avatar
Location: Lufkin, Texas In the Piney Woods Of East, , USA
my brake lights are intermittant. I have checked the relays, fuses and i replaced the brake/cruise switch on the handlebars. But it does not matter if i use the brake pedal or the handle bars to brake still the same. sometimes i hit the brakes and the lights come on a second or two later. where do i start . thanks guys ride safe.
pray for our troops. John 3-16.. you never lose until you give up.
KC5TF is offline
post #2 of 8 (permalink) Old 10-31-2010, 06:32 PM
Halfling's Avatar
Model: 2003 GL1800A
Send a message via Skype™ to Halfling
It's a 2001, do you know if it had Wig Wag brake lights installed or have they always been normal as in "not-modified"?
2003 GL1800A Candy Durango Red
US Navy (77-93) EWC(SW)
Darksider # 817 (195-55-R16 Michelin Primacy Alpin PA3 ZP @ 29.5 lbs)
Co-owner
"Seek out that particular mental attribute which makes you feel most deeply and vitally alive, along with which comes the inner voice which says, 'This is the real me,' and when you have found that attitude, follow it." - James Truslow Adams
Halfling is offline
post #3 of 8 (permalink) Old 10-31-2010, 06:33 PM
jackjohn's Avatar
If you have a brake light pulsing device on the bike, try taking it out of the circuit for a test.
Jack
2012 GL1800A
2004 GL1800A Sold
1982 GL1100I Sold
1975 GL1000 Sold
1974 CB450 Sold
jackjohn is offline
post #4 of 8 (permalink) Old 10-31-2010, 07:51 PM
junior moderator
If not a modulator causing the problem replace the brake light relay. 3rd relay from the right on the front row.
[SIGPIC]
post #5 of 8 (permalink) Old 10-31-2010, 10:40 PM Thread Starter
KC5TF's Avatar
no modulator om bike unmodified
KC5TF is offline
post #6 of 8 (permalink) Old 11-01-2010, 10:01 AM
Buzzmoe2's Avatar
I suggest you hold the brake pedal or brake lever as to activate the brake lights. Then while holding one or the other open and close the trunk lid slightly so the wiring harnesses at the trunk lid hinges get some movement. Watch to see if brake lights come on and off. i.e. may be just a broken wire in the wiring harness at the bend.
The second mouse usually gets the cheese.
Buzzmoe2 is offline
post #7 of 8 (permalink) Old 11-01-2010, 10:08 AM
FlyBoy212118's Avatar
I KCTF
To verify you switch on your handlebar right, just stick it
FlyBoy2121
FlyBoy212118 is offline
post #8 of 8 (permalink) Old 11-01-2010, 03:26 PM
magneto mike's Avatar
That does happen and one of my riding buddies with an 03 had to solder in new wires after the trunk lid chopped through his.
magneto mike is offline
2001 GL1800 No Brake Lights newday777 Goldwing Technical Forum 5 06-05-2012 02:59 PM
2001 1800 goldwing alternator problems slberry427 Goldwing Technical Forum 3 01-28-2011 07:59 PM
2001 1800 goldwing another oil question slberry427 Goldwing Technical Forum 7 01-27-2011 08:26 PM
2001 1800 mirror lights stopped working, signal do work newday777 Goldwing Technical Forum 4 11-17-2010 03:55 PM
brakelight modulator for my 2001 1800 Goldwing KC5TF Goldwing Technical Forum 8 12-03-2006 07:12 PM
