post #1 of 12 (permalink) Old 12-06-2010, 10:29 PM Thread Starter
gumbyred's Avatar
Model: 1998 S.E.
This is for a friend of mine who owns a 2001 Gold Wing. He used reverse to back up, and can`t get out of reverse again. Tried rocking it. Reverse light stays on. He managed to use reverse gear to get it onto a trailer, and there it sits. Any ideas????
Tom Bishop
`98 S.E.
1998 Gold Wing S.E. with 215.106 miles
gumbyred is offline
post #2 of 12 (permalink) Old 12-06-2010, 10:50 PM
I just had one stick on me today. Its the button, get some electrical spray cleaner and a little flat screwdriver and work it until it pops loose...
wingman81 is offline
post #3 of 12 (permalink) Old 12-06-2010, 11:47 PM
da_bull's Avatar
Year: 2001
ditto on the button. I put my thumb on the button, press it in, then pop my thumb off of it quickly. It sometimes takes a time or two, but it disengages. The fix, which I will do this winter, is take it apart (watch for springs) and spray the contact cleaner wingman81 spoke of throughout. Then your good for many miles...
Bill
Road Captain, CMA Chapter #105 Ozarks Christian Riders
01 GL1800 (current) Goodyear Assurance 40psi
past bikes:
02 GL1800
91I GL1500
84I GL1200
06 V-Star 1100 Silverado
05 V-Star 650 Classic
03 Suzuki GZ250
If we ever forget that we are One Nation Under God, then we will be a nation gone under...Ronald Reagan
da_bull is offline
post #4 of 12 (permalink) Old 12-07-2010, 02:01 AM
Wing-Rider's Avatar
Model: 2012 GL1800 Red
Send a message via Yahoo to Wing-Rider
I did a warranty on mine. I gotta do it myself next time!
All I wanna do is ride, ride, ride!....And enjoy every minute of it too! Used to own a GL1500!!
Wing-Rider is offline
post #5 of 12 (permalink) Old 12-07-2010, 05:56 AM
GWEddie's Avatar
The time I got caught like that I rocked it back and forth while jabbing the button, and eventually it fell out of reverse.
Lucky Eddie.
GWEddie is offline
post #6 of 12 (permalink) Old 12-07-2010, 07:56 AM
wingsam41's Avatar
This is a guess-don't own an 1800- what about disconnecting battery for a few min then reconnect. Anyone know if that might help?
wingsam41 is offline
post #7 of 12 (permalink) Old 12-07-2010, 08:03 AM
"This is a guess-don't own an 1800- what about disconnecting battery for a few min then reconnect. Anyone know if that might help?"
That may work in logic...but, the way the 1800 is, it doesnt matter if you disconnect batt or not...the button is still engaged and is telling the motorcycle its still in reverse. So when you connect the batt back in its still going to be in reverse.
post #8 of 12 (permalink) Old 12-07-2010, 12:11 PM
ARKnapp's Avatar
Model: None
Can someone with this potential problem post a picture of this bad button. There are mushroom shaped buttons or the like that can actually be pushed and pulled, it might be as easy as replacing.
Is the button interconnected with mechanical stuff or is it just electrical?
A look see with dimensions would be helpful in searching, thanks!
ARKnapp is offline
post #9 of 12 (permalink) Old 12-07-2010, 03:22 PM
here is the switch on the 1800 tore apart...
http://www.pbase.com/fredharmon/imag...5495/large.jpg
post #10 of 12 (permalink) Old 12-07-2010, 03:36 PM
wexy's Avatar
There is dirt in the button , sane thing happens on the other side with the Mute button , So turn off the ignition and spray wd40 into the button and flick the button (not press) in and out until it frees up , it will come out fully eventually and then spray some more wd40 in and press the button in and out several times , after a few minutes turn on the ignition and try it , Should work ,, Ciaran
CIARAN (pronounced Keeron)
yes it is Gaelic
wexy is offline
1800 reverse tankertc Goldwing Technical Forum 1 08-18-2012 01:48 PM
gl 1800 reverse cycleman0622 Goldwing Technical Forum 8 04-02-2012 03:31 PM
Mr V's problem in reverse Kefltrvlr2 Goldwing Technical Forum 4 04-27-2009 07:48 PM
reverse problem TedB1224 Goldwing Technical Forum 4 04-11-2009 04:38 PM
reverse problem??? siebo Goldwing Technical Forum 4 02-09-2009 11:22 PM
