post #1 of 4 (permalink) Old 01-23-2011, 03:42 PM Thread Starter
I am trying to find out the location of the main fuse and relay box.
Thanks!
rh48 is offline
post #2 of 4 (permalink) Old 01-23-2011, 03:51 PM
hunter27h's Avatar
Left side of the bike under the side cover be careful with removing the side cover to not break the tabs, two on the back of the cover two on the front. on the back I slide my fingers up under the set and gently pull outward on the cover
You will have to loosen all of the bolts on the left saddlebag to get the relay cover off.
Ben
hunter27h
"fair winds, and following seas"
"an old Goldwing, for an old guy"
1 1985 LTD "Bells"(1) "Bells" is now a trike (triwing classic)
1989 Goldwing 1500/6 "Glory" 148,000 like new miles
1991 Gold Wing SE Anniversary edition 39000 miles #647, "truly the fastest color"
Ben
hunter27h is offline
post #3 of 4 (permalink) Old 01-23-2011, 03:52 PM Thread Starter
Thanks!!!
rh48 is offline
post #4 of 4 (permalink) Old 01-23-2011, 05:16 PM
Senior Guru
agnogel's Avatar
you wont need to touch the saddle bag just take the seat off and the relay box will slide out after you remove the two bolts holding it then you can unclip the cover the fuse cover will just clip off no removal necessary
Peter
agnogel is offline
Fuse box cornbreaddaddy For Sale/Wanted Forum 10 04-25-2011 08:38 AM
fuse box mmonsterbuck Goldwing Technical Forum 3 02-20-2009 08:48 PM
fuse box 2 mmonsterbuck Goldwing Technical Forum 2 02-20-2009 08:02 AM
Fuse Relay Box GeorgiaBoy12 General Motorcycle Discussion Forum 1 10-15-2008 06:31 PM
1988 GL 1500 Fuse & Relay box, and # 3 relay KENT Goldwing Technical Forum 1 12-11-2007 09:09 PM
