post #1 of 4 (permalink) Old 02-16-2011, 06:07 PM Thread Starter
Down
Down's Avatar
Year: 1996
Model: Gl 1500 Aspencade
Send a message via Yahoo to Down
Ok so ive read on here about 7mm solid copper core spark wire and ive seen 19 strand tinned copper core wire, my question. is the stranded wire ok to use or should i use solid copper thanks to all
Take the long way around!
Down is offline
post #2 of 4 (permalink) Old 02-16-2011, 06:32 PM
"solid copper core spark wire" is a misnomer as it's actually stranded for flexibility so yes you're looking at the right stuff.
Ken Bergen is online now
post #3 of 4 (permalink) Old 02-16-2011, 10:23 PM Thread Starter
Down
Down's Avatar
Year: 1996
Ok cool thank ya sir
Down is offline
post #4 of 4 (permalink) Old 02-17-2011, 01:36 AM
neoracer's Avatar
Model: 87 Aspy,SEI,LTD
if you want an easy no hassle solution replace your wires with these wires which have pre-molded spark plug ends and correct angle to replace the worthless NGK caps,have done two bikes so far,over a year ago and absolutley no problems,just put one end on sparkplug,run wire to coil and insert,done
http://www.summitracing.com/parts/TAY-73253/
one kit does two bikes
in fact if someone wants one set of bare wires and still wants to use the ngk caps, $18 shipped to you us,canada $20
ps changing wires on the aspencade/int is a 25 min job,on
on the SEI/LTD's its about 1 1/2 hours if your lucky
neoracer is offline
gl1000 spark plug wire Cotten_David Goldwing Technical Forum 6 06-29-2009 11:04 PM
Spark plug wire john424 For Sale/Wanted Forum 7 04-15-2009 10:29 PM
broken spark plug wire? broken spark plug boot? AmpGoes211 Goldwing Technical Forum 8 03-29-2008 07:36 AM
Spark Plug Wire smketr1100 Goldwing Technical Forum 4 05-14-2007 11:07 PM
Spark Plug wire issue IronX Goldwing Technical Forum 4 05-07-2007 08:13 PM
