post #1 of 9 (permalink) Old 03-16-2011, 03:49 PM Thread Starter
Forum Toolmaster
flyboyziel56's Avatar
I tried looking up in the OEM service manual the procedure for changing out the front fork oil on the 1500 and it appears to show me the fork assembly needs to be removed?. Is this right?. I couldn't find a plug in the illustration. Any help would be most appreciated!!. Allan
"I\'m the Dude Playin the Dude Disguised as the other dude!!!"
Previous owned machines: CB750four,KZ1000,KZ900,Titan500,550GT,750GT,305Dre am,Triump tiger cub, CZ, BSA, Norton, H1, H2, The lists goes on!!!!!
flyboyziel56 is offline
post #2 of 9 (permalink) Old 03-16-2011, 05:48 PM
Older and Wiser
BenMC's Avatar
Model: GL1500 Aspencade
Easier on a GL1500. The top caps are easier to take off. Most of them have a 10mm drain bolt, its the one just above the allen bolt this guy is working on.
Ben.
BenMC is offline
post #3 of 9 (permalink) Old 03-16-2011, 06:01 PM Thread Starter
Forum Toolmaster
Ok so filling them is????
post #4 of 9 (permalink) Old 03-16-2011, 10:01 PM
PurplePirate's Avatar
Year: 1996
Make: Goldwing SE
Model: 1996 GL1500SE
After you get all the oil out you just remove the Air valves then the new oil is added through the air valves on the 1500 you want it to be 5.5 inches from the top. Look it up in the tech posts Rudy has a real engenious way of doing it otherwise the service manual says (right fork 320cc/10.8oz/11.4 imperial oz)
(left fork 325cc/10.9oz/11.2 imperial oz)that's from my Honda 1993 GL1500 service manual page 2-6.
Any sufficiently advanced technology is indistinguishable from magic.
~ Arthur C. Clarke ~
Always look for the door "C" it may be hidden but there is always one there...
PurplePirate is offline
post #5 of 9 (permalink) Old 03-17-2011, 02:31 AM
pwhoever's Avatar
DO NOT and I repeat DO NOT fill it 5.5 inches from the top. This figure comes from people misreading the instructions from the Progressive fork spring installation. No where on there does it say to fill GL1500 fork tubes to 5.5 inches from the top. They have only published 1 set of instructions that cover ALL street bike fork spring installations. It tells you to follow your service manual for proper filling. The properlevel is also with the springs out and the forks fuly collapsed. If you fill it to 5.5 inches from the top with the forks extended and the springs in, this is about 10 inches overfilled, guaranteed to give you one of the roughest rides you have ever experienced and will probably kill your fork seals. Read this thread if you plan on doing it through the schrader/air valve: http://www.goldwingfacts.com/forums/forum1/110432.html
Mike K.
97 Aspencade - Pearl White
Darkside Rear Tire- Austone 175R16
Double Darkside Front-Battl-Ax BT-45 130/70-18
2014 starting mileage- 60106
Darkside #1659
pwhoever is offline
post #6 of 9 (permalink) Old 03-17-2011, 09:19 AM Thread Starter
Forum Toolmaster
I'm in total agreement!!. I'm just changing/checking the oil in the front. And your 100% correct on not filling it 5.5 inches from the top!!. Here below is an inset directly from the Progressive web site about filling shocks " AFTER " you have removed the springs from your front end!!!.:re adit:
Fork oil level/volume should be checked according to the steps outlined
in your authorized shop manual. Measurement of your fork oil
by level is the preferred method. However, some manuals only specify
a volume measurement. Due to the design of a progressive wound
fork spring it will displace more oil thus requiring a maximum oil
level of 5.5" (140mm). Caution: This is not a recommendation,
it is only a precautionary statement
. If your manual specifies an oil
level higher than 5.5"
(140mm) set the oil level
at 5.5" (140mm). (Oil
level is the distance
from the top of the
fork tube to the top of
the oil with the fork
completely collapsed
and the fork spring removed.
post #7 of 9 (permalink) Old 03-17-2011, 09:49 AM
The Irish Crew
Heffo's Avatar
Progressive couldn't have made that more confusing if they tried.
Dave Heffernan.
Heffo is offline
post #8 of 9 (permalink) Old 03-17-2011, 07:31 PM
road_rascal's Avatar
Send a message via Yahoo to road_rascal
Ok, with Progressive fork springs what's the recommended amount (in cc's) for the fork tubes? I'm going to be changing mine soon on my '98.
Thomas K.
1998 Aspencade,
Past scoots: \'04 Ninja 250, \'97 Nighthawk 750, \'82 KZ750, \'82 KZ440, \'82 Maxim 400 \'99 Yamaha SH50
road_rascal is offline
post #9 of 9 (permalink) Old 03-17-2011, 07:57 PM
pwhoever's Avatar
Even though the amounts are important, as long as you set the correct level, you will be fine. Each fork will have different amounts because of different components but the measured level will be the same in both. The correct amounts only come into play if the forks are completely drained which wont happen using the drain plug method. There will still be some left behind. But setting the correct level will work fine. Take a look at this thread and go down to the post by Satan. I would consider him the guru of gl1500 fork levels: http://goldwingfacts.com/forums/view_topic.php?id=66332
Mike K.
Darkside #1659
pwhoever is offline
GL1500, changing fork oil Wingrider59 Goldwing Technical Forum 3 03-21-2012 02:33 PM
Changing out the fork oil on a 92 1500 Aspy Dusty Boots Goldwing Technical Forum 13 04-05-2009 01:09 AM
changing front fork oil redlord Goldwing Technical Forum 1 09-11-2006 11:18 PM
Changing fork oil. How much to add? b.pete Goldwing Technical Forum 4 11-12-2005 11:11 AM
Changing the fork oil underwing Goldwing Technical Forum 7 09-19-2004 09:55 AM
