post #1 of 5 (permalink) Old 03-20-2011, 11:36 AM Thread Starter
Luxo2r's Avatar
Model: GL1800 - 2002
Send a message via Yahoo to Luxo2r
Friend has an 1800 and no rear lights, no signal/brake/running no low beam and no horn . . . . . . any idea's???
Al B
How many wrenches can one man own? Don\'t ask silly questions!
GWRRA Life Member #15513
Former MSF Instructor
Mason - Shriner - 2B1ASK1
American Legion SAL Post #166
Thanks to all those who served.
Luxo2r is offline
post #2 of 5 (permalink) Old 03-20-2011, 12:08 PM
MichiganWing's Avatar
Model: 2007 Gl1800 HPN
Sure..pick 1 trouble, grab the service manual and work thru it. It'll likely lead to a commonality that accounts for the rest of the faults.
Shiny Side Up !
Jim
MichiganWing is offline
post #3 of 5 (permalink) Old 03-20-2011, 12:41 PM
Does the engine run and the high beams work? I can find nothing in common with all those things that would still allow the engine to run except possibly the main ground.
I am looking at the 06> manual, what year is the bike?
[SIGPIC]
post #4 of 5 (permalink) Old 03-20-2011, 04:36 PM Thread Starter
Luxo2r's Avatar
the bike is a 2003. The running lights were on after all, what else i found was one of the fuses on the right side of the fuse block was put back in the wrong place when checking them for continuity. that fuse controlled the horn and the turn signals and the brakes. now for the low beam head lights issue, both low beams non working. in looking over everything and checking the relays i suggested we pull one of the bulbs and sure enough it was burnt out and luckily he had one replacement. found the other buld burned out as well. we have no idea what caused both bulbs to both burn out at the same time . . . but stuff happens!
Thanks to the members that posted responses . . . SALUTE!!
Al B
Luxo2r is offline
post #5 of 5 (permalink) Old 03-20-2011, 06:29 PM
The simplest of things.
[SIGPIC]
GL1800 Lights dusty88 General Motorcycle Discussion Forum 6 09-12-2012 10:46 AM
GL1800 Dash Lights vagrant50 Goldwing Technical Forum 1 08-22-2011 03:58 PM
high lights out gl1800 glyn7255 Goldwing Technical Forum 2 11-11-2009 08:16 PM
GL1800 lights ezryder1528 Goldwing Technical Forum 3 04-26-2008 04:52 AM
PIAA Lights & Fog Lights for GL1800 Stephen Johnson Goldwing Technical Forum 2 01-23-2006 11:31 AM
